I agree, and active crossover on the line level would be ideal. However, you will need to have 4 channels of amplification for your front speakers. So if you have 6 channels you can provide to the 6 speakers, then go for it. However, if you only have a 4 channel amp (or two 2 channels, whatever) then I would recommend using a passive between the woofer and satellites. Mine is wired this way and it sounds fine. Most of the sound mixes anyways, this just ensures that the tweeters don't erupt.Originally Posted by cbergeron
LinkBack URL
About LinkBacks
Did you remove the monsoon "black box"?
