I have the same problem. I can say for a fact that noise filters and ground loop isolators on the RCA's will not always help in this case. I also get noise through the VGA cable, using high quality VGA coax cables with ferrites on both ends.
I have almost given up, attributing it to the simple nature of these cheap switching DC-DC power supplies.
One option, if the correct voltage is available for you, is to use the carnetix power supply to power the laptop.
I have stopped worrying because I have decided to go to a micro atx/opus solution. The laptop had so many other problems that it is not worth the hassle.
Goodluck!
LinkBack URL
About LinkBacks
what shoud I do GLI ?? or what) PS Nobody in my poor cantry don't wont to help me, they say that there can be toomany posibilitis and too many work to find the problem. But i know the dc - dc adapter makes all the mass.
