Actually the + and - does matter. Generally keep everything the way the manufacturer has it marked, because you may shoot yourself in the foot if you decide to add speakers later. It is important that you wire your speakers consistantly, that means, decide which is + and do that for ALL speakers. If you do not, then your speakers will be "out of phase". This means that while one speaker is "Pushing" the other is "pulling". This means that while one speaker is creating rarefactions, the other is creating compressions and vice versa. The waves will end up canceling each other out (not completely, but enough for it to be vital).
Oh, and be careful while hooking your speakers up to your home system. Most home systems are rated at 8ohm and most car speakers are 4ohm. If this is the case, simple wire two speakers in
series and attach it to one channel on the amp.
(AMP+) ----- (+Speaker-) ------ (+Speaker-) ----- (AMP-)
