You will need a device in the middle that coverts the digital signal to light.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Im getting a phoenix gold octane R5.1M amp that has toslink but where can i get the cable that connects to my VIA M10000 mobo?
thanks
I thought the R5.1MT came with both a digital coax and digital optical input! If it has digital coax then you run a wire direct from epia to amp!
brent
1999 Nissan SE-L - turbo toy
1993 Nissan NX - Turbo Racer
Standalone fuel management (AEM EMS) on both
carPC
can someone please clarify which way im supposed to hook up this amp to my M10000?
do i use that converter to go from mobo to converter to toslink cable to amp?
or do i just use regular coax rca cables from the SPDIF of the mobo to the coax input on the amp?
thanks guys.
bump
I tried using a regular rca cable from the coax input on the amp to the SPDIF on the EPIA VIA M10000 mobo and it would work.
Do i need to get that converter to work?
i thought i could use coax input.
the coax input is still a digital signal while rca is still analog. if your amp supports digital, you might want to look at getting some kind of digital converter for your sound card, or add a sound card with digital(optical sounds great) out. my home computer connectes to my theater system via toslink, with a audigity w/ optical out add on card. you may want to read up on toslink, because the longest cable i have been able to successfuly find is 6ft. not sure if it has anything to do with the specfication.
Crouching Tiger, Drunken Kitty
Originally Posted by cheerio
do i have to connect to the sound card? i wanted to use the SPDIF on the motherboard.
and i only need the cable to be about a foot.
is there no other way to do this without the digital converter?
thanks
