Results 1 to 10 of 18
Thread: Best way to mount Bazooka
    Raw Wave tj!2k4's Avatar
    Oct 2004
    A co-worker gave me one of these for my carputer project.. what's the best way for me to mount in in the trunk.. eg. which direction do I want to point which end, where do I want to place it in the trunk, and what's the best way to keep it from shifting around?
    Low Bitrate ALonDonThinG's Avatar
    Aug 2004
    London
    Experiment for position, will be best to use straps to tie it down.
    Epia SP1300\512 ddr\40g 3.5" hd\cartft-touchscreen\GPS-destinator \M1-ATX\Audigy1\Linksys-wirelessB\anafekkingbigamptojblspkrs.
    Variable Bitrate nottastocker's Avatar
    Jun 2003
    Shenandoah, VA
    i prefer a bazooka akin to myself
    is the sub box sealed? if it is, then there is no matter of where it is facing. if it is open ended, just point the open end into what ever freespace you have in your trunk
    Oct 2004
    The speaker is behind the grill you see in the foreground. The other end is sealed, and is also where you connect the wires.
    Constant Bitrate cbergeron's Avatar
    What kind of car do you have? Is it a Sedan or Hatchback?
    We have an BTA10200 in our car and it Rocks. The instructions say to put it in the rear right corner of the trunk, with the woofer/port pointing toward the back of the car.
    Here's a link to the instructions:
    http://www.sasbazooka.com/pdf/current/Tubesmanual01.pdf
    Kind regards,
    CB
    DashPC - The Linux Car (since 1999).
    Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
    As seen in the book Geek My Ride
    _
    Mar 2004
    Little Elm, Texas
    it all depends on how you like your bass to sound....first and foremost, you aren't going to get very good sound out of a Bazooka, period. But for some people, it's perfectly fine. Go with what ALonDonThinG said, you will just have to test different positions. It will depend on yoru music tastes, your car configuration, etc as to where you end up liking it the best. As for how to secure it, Bazooka tubes use to come with straps for tie down...you shoul dbe able to go to most audio shop that sells them and either get a set for free of pay a few bucks and get a set.
    Jan Bennett
    Oct 2004
    Werd. I realize that that lil 7" speaker isn't gonna blow the doors off the car, but then again, it was $free$, so I'm not gonna complain. =)
    Thanks for the info. I listen to everything, really.. I'll play around with situating it in the trunk when I get my car back, and in the meantime I'll look into getting some straps to fasten it in place.
    Constant Bitrate mbuchman's Avatar
    Feb 2005
    I have heard bass is at its best 8 feet away, but not sure on how true that is. What I do know is you want it as far back in your trunk as you can to prevent cancelation. If you have it say in the middle of your trunk, then half of the sound travels to the back of the trunk and the other half goes up to you, then bounces off the windshield, and wherever the 2 reflections meet, their is the least sound due to cancelation. So if you have it as far back as you can, you are usually safe.
    Matt
    Edit: And yeah, for free, its hard to pass anything up, but I have never heard anything good about the Bazooka tubes. Still though, it will add bass, so may as well put it in!
    FLAC ppgt94's Avatar
    May 2001
    USA
    I think most Bazookas are ported (not sealed). If you have the one in the picture it's ported.
    _
    Mar 2004
    Little Elm, Texas
    This is true in a situation like home theatre, in a car however, you have too many things that will get in the way of that traveling wave
    it's going in a trunk, it's not like there will be that much of a difference in distnace when talking about mose trunks.
    one thing that some have had tried and had good experience with. If you will place the tube with the speaker firing into a corner, placed about as far away from the corner as the diamater of the speaker. Apparently a lot of people have had good luck with this set-up....=]
    this is generally true, just in a car it's not much of an issue, unless you are talking about a suburban or the like...=]
    I'll agree here. I would take it and sell it and use the money for something better...lol
    but that's just me, =]
    Jan Bennett
  1. Dash mount screen in GM Chevy Tahoe
    By slushieken in forum LCD/Display
    Last Post: 06-19-2006, 04:31 PM
  2. Arm Mount
    By kirk in forum Fabrication
    Last Post: 05-29-2004, 12:25 PM
  3. Looking for an arm mount system
    By carpal tunnel in forum LCD/Display
    Last Post: 02-21-2004, 05:04 PM
  4. Replies: 0
    Last Post: 07-14-2003, 04:12 PM
  5. prpoer way to mount hardrive
    By asif in forum General Hardware Discussion
    Last Post: 07-11-2000, 11:12 AM
