Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 2000 Mitsu Eclipse GT Aux-In
  1. #11
    Low Bitrate sxt173's Avatar
    Feb 2005
    New York
    Quote Originally Posted by takissd
    I think i still havea diagram of the eclipse audio cabling i will check at home and attach it if i do.
    So, do you have it? Also, didn't know my amp was under the passenger seat. Is this true on the 2000 GT also?
    Where did you and the other guys put the pc?
    Planning on under dash on passenger side, all the way in the back. Have the PC in a really small custom built case (will psot picks when I have it done). Will mount HD seperately.
    What would be really cool would be in glove compartment, but not sure if it will fit. Just hopeful thinking. (btw, its a mini-ITX)
  2. #12
    Low Bitrate Erorus's Avatar
    Feb 2005
    I have my (too large) custom case behind the passenger-side back seat, in the trunk. Wires are routed under the back seat, thru wire loom to under the driver's seat.
  3. #13
    Low Bitrate cyber's Avatar
    Jun 2004
    Frozen Tundra
    I currently have the computer in a travla c134 din case residing in the bottom din with a digitalww pullout touchscreen in the upper din. This summer I'm changing my setup, storing the computer in the center console (arm rest area) and installing the pxa-h700 control face in the bottom din.
  4. #14
    Constant Bitrate takissd's Avatar
    May 2004
    San Diego, CA
    here we go...
    ok, sorry for taking me so long, it was not in the directory i thought due to a recent disk format but i got here it is. also attaching anoyther file i had from the 3G forum...
    I mounted my pc in the trunk. i have a travla C134 black with the opus 90W inside. They all fit in there. This is good, i can take it out of the car anytime i need and it looks cleaner too.. maybe i will take some pics.. Also i didnt want to do too much cause i am planning to get another car soon. So i wanna be able to return it to stock as easy as possible. hope the files help
    Attached Files Attached Files
    -VIA EPIA M10000/512MB/40GB HD
    -DWW motorized 7'
    -BU 303 GPS w/iGuidance/ CF
    -Belkin Bluetooth
    -Pioneer HU
    [||||||||||] 95% done
  1. 2000 Grand Am GT
    By cavramair in forum Show off your project
    Last Post: 12-13-2004, 08:17 PM
  2. 2000 Silverado Aux Adapter
    By Jailer in forum General Hardware Discussion
    Last Post: 10-12-2004, 07:41 PM
  3. My 2000 Mitsubishi Eclipse Setup
    By mestre in forum Show off your project
    Last Post: 04-30-2004, 01:19 PM
  4. Lilliput LCD, 2000 Celica GT and voltage problem
    By Goose in forum LCD/Display
    Last Post: 12-29-2003, 04:53 PM
  5. 2000 Mustang GT Convertible Mp3 project
    By mp3stang02 in forum Show off your project
    Last Post: 05-24-2003, 03:45 AM
