Results 1 to 4 of 4
Thread: Dodge Neon Radio Pinout?
    I looked around google for a while didnt find a thing. I just need to know what is power ground and one set (+/-) of speakers pins. Thanks in advance. Note that the radio has a black and a grey connector on it each 7 pins long.
    Elsewhere
    Quote Originally Posted by hcker2000
    2000 Neon: http://www.the12volt.com/installbay/...D=9827&KW=neon
    Hope it helps.
    Check out the12volt.com for more...
    How about the Wiki?
    Kind of helps but none of the wires are actualy attatched to the radio at this point as it has been pulled out of the car and a new one installed. I was going to use this one for testing my speakers to see if they are bad. I got checking and my little gx-15 guitar amp has a 4 ohm speaker in it so im going to hook my speakers up one at a time to it and test it that way. So I guess I realy dont need the pin out after all but thanks any way.
    Aug 2006
    Original Radio
    Do you still have the original radio?
    I have a 2001 Neon, the radio broke down so I'm trying to find a used one
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  2. Dodge Neon Carputer /7" Touchscreen
    By CDesigns in forum Show off your project
    Last Post: 01-01-2008, 05:34 PM
  3. 1998 Dodge Neon R/T - Carputer Version 3
    By AJ Quick in forum Show off your project
    Last Post: 07-12-2006, 07:04 PM
  4. Dodge Neon R/T 1998 CAR PC
    Last Post: 05-07-2004, 12:01 PM
  5. Custom enclosure for a Dodge Neon, Amp, & Subs
    By tejohnson in forum Classified Archive
    Last Post: 06-17-2002, 01:38 PM
