Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Best way to connect 8 gauge wire to 12-16 gauge wire?
    Feb 2004
    Las Vegas, NV
    Finally have all my car audio and power parts in (amp, sub, amp install kit). Back seats and paneling have been removed from my car. Have a remote audio video switcher, as well as an inverter and other goodies. Anyway, just a few quick questions:
    I will have 4 gauge power cable from battery to to trunk distro block, at which point it will branch off into 3x8 gauge cables to feed an inverter and and amplifiers. These lead back to another ground distro block.
    I need some smaller 12 volt power lines to power a Sirius tuner, the amplified video switchbox, and maybe a rear view camera. Whats' the best way to get 12-16 gauge cable from the above setup? It's kinda unwieldy to wire crimp the 8 gauge and 16 cables together. I'm thinking I could solder one end of the 12 gauge cable to one end of the 8 gauge cable and then put that entire assembly into the distro block connector.
    Suggestions?
    _
    Mar 2004
    Little Elm, Texas
    8 gauge is a little big but.....
    you might be able to find something along these lines:
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    or this:
    Jan Bennett
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Quote Originally Posted by Red GTi VR6
    or this:
    You're just showing off now...j/k - you're setup is tight.
    Feb 2004
    Las Vegas, NV
    Cool, where do I get something like that?
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    ghetto style - twist and electric tape
    whatever you want to do man it will work just make sure its a nice tight seal especialy if its coming from ur battery.... why dont u wire the smaller stuff like camera to a fuse under ur dash or something its easier and u can choose if u want it to turn on when u turn the key or alwayz be on... have fun
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by hd54321
    lol - thanks
    you can get stuff like that at any home depot, lowes, electrical supply store, etc
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by xdjxklusivex
    this is about the most unprofessional way you could do it. it's not secure, and it's far from pretty, not to mention unsafe...
    but the fuse thing makes sense
    lol
    Jan Bennett
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    lol
    it may not be the best method but it works, it works especially well if you solder the wires then tape them up. i find connections where whe wires are only twisted and taped to hold up to abuse much better than any of the crimp style connectors commonly used
    Signature: [==||========] 20% complete
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Anyone used these things for splicing in?
    http://cpc.farnell.com/jsp/endecaSea...CBA-560B&N=401
    Could be ok for low power things
    And red, i have to second that - you are such a show-off But i am being jealous - wish i had the time, money and skills to make something that nice.
  1. What gauge wire for opus?
    By XxAndyxX in forum Power Supplies
    Last Post: 01-20-2004, 12:21 AM
  2. Routing power button to front of PC. Can wire be too thick of gauge?
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 09-27-2003, 03:32 PM
  3. 8 gauge wire BIG!?
    By detz in forum General Hardware Discussion
    Last Post: 07-11-2002, 03:23 PM
  4. Attn: 15' foot 80 wire IDE works. Paid 16 buks. -DVD-ROM (Say Yes!)
    Last Post: 02-14-2002, 05:05 PM
  5. how do I wire 16 x 2 LCD?
    By maromba in forum General Hardware Discussion
    Last Post: 04-07-2000, 10:01 PM
