Results 1 to 2 of 2
Thread: LineX USB FM Modulator??
    Feb 2005
    Has anyone tried this FM Modulator before. Pricey but it's bus powered!
    Check it out
    Nov 2004
    I have a Linex FM modulator, only the non-usb powered version. (uses 4 AA batteries).
    Soundquality is ok, and its very stable, during my drive last year on holiday (1200 km) I never had to re-scan the tuner, so the PLL does its work very fine.
    Only my unit has 8 pre-programmed frequencies, using dip switches, but thats not a real issue. Can't compare the soundquality to a regular radiostation, since i don't use the unit anymore.
    I was planning to make it battery-powered myself using a voltage regulator, but I decided to remove my HU at all and connect the carpc directly to an amp.
  1. Replies: 8
    Last Post: 02-13-2006, 02:27 PM
  2. USB FM Modulator? Found one.
    By Custommx3 in forum Car Audio
    Last Post: 01-12-2006, 08:27 AM
  3. USB FM modulator.
    By ppgt94 in forum General Hardware Discussion
    Last Post: 10-01-2004, 03:24 AM
  4. FS : LineX USB FM Modulator
    By Stavros in forum Classified Archive
    Last Post: 02-06-2003, 01:05 PM
  5. LineX USB FM Transmitter
    By grandamp3 in forum General Hardware Discussion
    Last Post: 12-21-2002, 01:36 PM
