watts is a unit of power, 2 channel means you have 2 channels, ie 2 rca ins and 2 speaker outs (for left/right) 4 channel obviously means 4 inputs and 4 outputs, its possible to run 2 speakers off one channel, its also possible to run 2 channels off 1 input. for subwoofers you can use a mono amp (one channel) or bridge (on a bridgable amp) 2 channels together.
you obviously need to do a lot of research on this to get you started learn these things before you start installing a car stereo
what watts means
what channels are
(these 2 should be covered now)
what speaker impedences mean
what bridging amps is about
also look into class D sub amps if you really want a kickass system
edit: and its very important you understand the differance between Peak and RMS watts
LinkBack URL
About LinkBacks
