Results 1 to 10 of 15
Thread: GM Factory AUX
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    GM Factory AUX
    So i have a 2001 pontiac sunfire with a factory upgraded radio. It is a pretty good unit and I'd like to keep it in my carpc setup. This headunit supports an "AUX" port. I assume it is designed for CD changers. I have found 2 products that i think will work. I have my Headunit in my room and it has a 12 pin connector, so i know it is a GM12 or a GM12-AUX. Apparently there is a big difference in that little AUX
    The first costs about 6 bucks... does anyone know if i can use this with my class II - RDS system in my car.
    1st one (GM12): http://store.yahoo.com/efunctional/pacabgm12.html
    If I can make this one work, I'd love to buy it
    The second one is 10 times the cost, and I can see the RCA inputs, i know i could make this one work for sure.
    here is the 2nd one(gm12-AUX): http://www.discountcarstereo.com/detail.aspx?ID=446
    Does anyone know anything about this, Maybe my GM dealer will help me out, but i doubt it. What about stores like best buy that do "free installation" with the purchase of a head unit, would they sell me the parts i need, or would they tell me which one i can use.
    I need any help i can get
    -drew
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    i have a 99 escalade and i have a factory tape player..slave cd player and cd changer all through factory headunit..everything is gm..i bought the aux input and what it does is you plug it into your headunit and than whatever was in your headunit into the aux box. mine has 2 inputs..it has a little switch included so i can pic between my aux1 input aux2 input and my stock cd player/changer..its pretty cool but i upgraded to a pioneer headunit with an aux input...its much easier!
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Im pretty sure you need the expensive one.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Feb 2005
    S Ohio
    i can't even use my wiring skills and warranty voiding powers to mod the cheap one so it works?
    My NEW carPC
    Oct 2004
    Nope, becuase the cheap one also requires this; http://www.sjgreatdeals.com/pacaux2car.html
    in order to work.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Feb 2005
    S Ohio
    what about this?:
    http://www.cybergiftcenter.com/appli...2&mpn=AAI-GM12
    it says: "In order to work, slave unit must continuously be playing or if XM Satellite Radio® or DVD, must be on " I don't understand crappy english, but does this mean that i must have my factory head unit on for this to function.
    If not, what does it mean by "slave unit must be continuously be playing"
    I hope this $35 solution works, My local pontiac dealer knew nothing
    -drew
    My NEW carPC
    Oct 2004
    That one means that you need to have the xm or cd changer option. If you didnt pay for those options then you cant use that.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Feb 2005
    S Ohio
    thank you n8scstm, i hate what you are telling me but I appreciate the fact that you are helping with this stuff. I don't want to spend this much on this part but it looks like I have no choice.
    how about this one?
    http://www.cybergiftcenter.com/appli...&mpn=AOEM-GM24
    My headunit has two plugs in the back one is 2X12 pins and the other is 2X6 pins. When i got my car ther 2X6 pin plug was empty, and the wiring harness from the car was plugged into the 2X12 plug, I assumed that if i was going to add anything into the headunit i'd have to use the 2X6 plug.
    But the link i just put up might allow me to hookup through the 2X12 plug and leave my radio intact?
    n8? any advice
    I should supply photos
    My NEW carPC
    Oct 2004
    No photos neceasary. I have a similar radio. It's the older 9 pin aux, but I know what you mean. They sure are vauge on their descriptions huh? I'm not really sure about that one. I think you're just gonna have to call them. I think if that one works, it will utilize a remote aux button rather than the one that is already on your stereo.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Jan 2005
    Chicago, IL
    if mine is the same as the one you need ill sell it for 50 shipped...ill take pics if your interested.
  1. GM (DELCO/DELPHI) Aux Input
    By superdave in forum General Hardware Discussion
    Last Post: 09-09-2009, 10:21 AM
  2. Dash mount screen in GM Chevy Tahoe
    By slushieken in forum LCD/Display
    Last Post: 06-19-2006, 03:31 PM
  3. Replies: 3
    Last Post: 12-03-2004, 04:51 PM
  4. Head Decks that DEFINITELY have AUX in?
    By inmytree in forum General Hardware Discussion
    Last Post: 11-02-2003, 12:56 AM
  5. AUX in's for hard to hack factory HU's
    By ddt in forum General Hardware Discussion
    Last Post: 12-31-2002, 07:19 PM
