Before I ask, I did do a
Having problem with audio. Just completed my install and here is what I have:
I built in a manual switch, which controls the 12V going from CarPC to relay, so that I can switch "on" to CarPC, or I can switch "off" to HU.
So, whenever I switch to the CarPC, all I hear is terrible, terrible interference, hissing and engine whine, but it is fine when relay is switched to HU. If I accelerate, I can hear it thru the speakers as whinning. Even the harddrive spinning creates interference sounds. The only time I hear
music is if I turn the volume on my carPC up all the way, where it muffles the sounds...
I used
radio-shack RCA cables and RadioSHack y-splitters for the section going from relay to CarPC. Also, there is a small section of the relay, where I had to use 22+ gauge wires..
WOuld changing all the wires to shielded high-quality wires work? PLease help
