Results 1 to 10 of 13
Thread: Audigy2 NX popping noises???
    Im not too sure why when the volume is turned above say.. 80% or so, my speakers start crackling... could this be clipping? i remember that my system before was alot louder than it is now.
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
    Jan 2004
    Jersey/NY
    when you say "i remember that my system before was alot louder than it is now."
    What do you mean by "before"
    Do you mean before you used the audigy2 NX and used onboard or some other pci sound?
    Also check to make sure there's no preamp or equalizer settings enabled in software or hardware (if audigy2nx supports hardware equalizer... i know just about nothing about it).
    Good luck.
    actually i had a indash flip out dvd/tv.. attached to an audiocontrol 6xs crossover , then that went into my balanced line drivers. though this setup took 20/40 clicks to get somewhere in the somewhat loud region, the audigy can pick up the same loudness at like 20% volume out of 100%... however the max before clipping on my in dash was around 38 clicks. but i had my gains set so the max volume would be reached around 30 clicks. and that was extremely loud, loud enough to make my windshield wipers move back and forth about an inch, and no popping noises there...
    id say at around 100% volume on the audigy is like 22clicks on the HU but this causes crackling/distortion. though i got rid of the audiocontrol cause it kept making stupid alternator whine and i had no place to put it after the carputer install.
    Variable Bitrate Squid's Avatar
    Jan 2004
    Pittsburgh, PA
    Hmm.. maybe you have your gains set too high on your amp....
    On my setup, I have the wave turned all the way up and adjust the system volume by master...
    I set the master volume at 75% with the amp gains all the way down... then I slowly turned up
    each channel till the speakers were as loud as they could be yet clear...
    then I tweaked them back just a tad... worked great...
    I can drive around with 2% volume to talk over and around 40 to 50% is slammin.. with high 70%'s just overly loud
    ..heh... (if something can ever be TOO loud)
    CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
    Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
    Display: Lilliput 7" TouchScreen
    CarPuter Install
    lol actually my gains are turned to 9v on the amp =P which is the lowest it will go....
    Low Bitrate killerfishes's Avatar
    Dec 2003
    you need to readjust the gain setting. look and see if there is a target voltige for your amp. if not use an ocilloscope, any way other way is hit or miss.
    now working on my Dodge Dak
    toshiba portege == done
    audigy2 NX == done
    7" flush mount == 0%
    pimp rating == 48%
    so pretty much youre saying i should match the gains for each device.. perhaps its my balanced line drivers thats causing the distortion...
    anyone know where i can "borrow" an ocilloscope?
    _
    Mar 2004
    Little Elm, Texas
    that's most definately distortion
    have you matched everything? have you matched your gains on your amp? have you matched your volume settings in your computer?
    I don't see the sound card as being the main problem here....
    you can use a 1khZ tone at 0 db to test this....put that in and play it, turn it up most of the way and go around and tune, you will hear the differnce once you start to have distortion, it's a slight difference, but it is noticeable
    Jan Bennett
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    Hiya Red
    I am hoping you got that "tone" in a downloadable format PLEASE !
    or email, I am sure we all could use something like that for tuning and setup purposes.
    Cheers
    and
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    _
    Mar 2004
    Little Elm, Texas
    I don't have it on this computer....
    but...
    you can probably find it online somewhere and definately on Kazaa
    Jan Bennett
  1. USB Audigy2 NX Standby resume issue
    By 00CericaRuss in forum General Hardware Discussion
    Last Post: 12-05-2004, 02:32 AM
  2. Audigy2 NX LineIn No Surround?
    By djScript in forum General Hardware Discussion
    Last Post: 10-26-2004, 11:32 AM
  3. Audigy2 nx bass output confused
    By rickyaswell in forum Car Audio
    Last Post: 10-08-2004, 02:32 PM
  4. Audigy2 NX sound
    By nirvanades in forum General Hardware Discussion
    Last Post: 09-02-2004, 08:03 AM
  5. Audigy2 NX and MediaCar problem
    By nirvanades in forum MediaCar
    Last Post: 08-20-2004, 06:33 PM
