Results 1 to 4 of 4
Thread: Dim lights on display
    Mar 2005
    My roommates antenna wire came loose and stopped pulling in radio stations. So we took out the radio and re attached the antenna cable. Now the front panel display is very very dim, but it was not dim before we took out the radio. Any suggestions on what the problem could be?
    we pulled it back out and all the connections seem good between the wires.
    Constant Bitrate HostileJava's Avatar
    Mar 2005
    Northampton, PA
    Most radio's have a dimmer line that run to them, when you turn on the headlights it dims the radio because it assumes it's dark out and doesn't need to be illuminated as much. Identify that wire and make sure it's not loose.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    also disconnecting power returns most to factory defaults... you may have a manual dimmer setting (my HU does)
    Read the FAQ!
    Mar 2004
    Little Elm, Texas
    some headunits will also be tied into the dimming option for your dash board....
    I know on my car and on the truck you can dim the dash board lights and sometimes it will dim the radio as well...
    might want to check that as well
    Jan Bennett
  1. D3 in C# application
    By jadz in forum Map Monkey
    Last Post: 11-18-2004, 09:29 AM
    By IntellaWorks in forum Software & Software Development
    Last Post: 11-05-2004, 08:20 PM
  3. Replies: 4
    Last Post: 10-04-2004, 01:00 AM
  4. Any way to relocate my display card??
    By SlimJimmy in forum General Hardware Discussion
    Last Post: 03-22-2004, 09:14 PM
  5. Choosing a Character display...
    By Kryten in forum LCD/Display
    Last Post: 10-16-2003, 10:43 PM
