actyally, this is correct, to a point....it's definately not complete BSOriginally Posted by froop
DISTORTION is what will kill a speaker.
By running too little power on a speaker, you will naturally turn it up because you aren't getting the power out of it that you want. Thus the statement above. When turning up those amplifiers that are under powering those speakers, you are pushing that amplifier to its limits, and you will induce distortion because of this. Since the amp is being asked to produce more power than it is built for.
by running too much power on a speaker you are less likely to feel the need to turn it up. usually when you run too much power you are not using all of that power, thus you are not running into the limits of the amplifier. Thus....less distortion.
is it not ture that distortion can lead to more heat in a coil thus causing thermal overload?
So no Blackrazor...froop is not completely wrong...just not fully explained...lol
you are both saying the same things, just getting about them in different ways...
LinkBack URL
About LinkBacks
using
word
