Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Powering AMP and CarPC
  1. #11
    Constant Bitrate mbuchman's Avatar
    Feb 2005
    Quote Originally Posted by Red GTi VR6
    ghetto internet talk yo!
    lol
    disto block is your best bet - it will make things a lot easier....
    you can do what I did - which was to run your single power line from the battery - fused within 18 inches of the positive terminal of course, to a distrobution block that has fusing as well....that way you have double protection, which would be a good idea to do anyways. I have a 300 amp fuse up front, then a 20 amp fuse at the disto block for teh computer and 2 80amp fuses for the amplifiers.
    Yeah, any time you split one wire into more, you should fuse for a few reasons. The main reason is if you have a nice 200A fuse at the battery, run 1/0 to the trunk, and split it into 2 4 gauge lines without refusing at the distro block, then if you get a short, you could get an electrical fire because the 4 gauge wouldnt be able to handle the 200A before the fuse pops! So you may think "well the amp has its own fuse", but definately fuse every time you make a new connection (aka after the battery, and after a split)
    Matt
  2. #12
    Jun 2003
    Thanks for the info guys!
    I was planning on having just one fuse right after the battery positive but I guess I will put additional fuses after the disto-block to make sure!
    /L-O
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    coming from someone who had a car fire due to an installers negligence...
    I fuse every chance i get...and I also don't let anyone else touch my car - that fire is really what drove me to get into installing on my own...lol
    Jan Bennett
  4. #14
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    =======<=>==|<=>_|..................fuse.......... .| BATTERY|
    =======<=>==|<=>_|==========<=>======|+_______|
    fuses fused dist block
    So you are saying this would be the best way to go? BTW, on a inverter, do you run the black wire to the negative term on the battery?
    Like my schematic? the ........are to indicate nill, nada, nothing.
    2000 Sunfire build 100%, or is it ever really 100%?
  5. #15
    _
    Mar 2004
    Little Elm, Texas
    black is usually just a ground...
    Jan Bennett
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. Dodge Ram 1500 (Hemi) carpc
    By pirate_king00 in forum General Hardware Discussion
    Last Post: 04-03-2005, 05:03 AM
  3. Replies: 20
    Last Post: 10-31-2004, 10:53 PM
  4. Sound not very loud have i bought the wrong amp
    By rickyaswell in forum Car Audio
    Last Post: 09-26-2004, 11:23 PM
  5. Those with a hu, amp, and carpc
    By falconey in forum Car Audio
    Last Post: 09-14-2004, 08:27 AM
