Results 1 to 10 of 15
Thread: Powering AMP and CarPC
    Jun 2003
    Hi,
    I am about to install an amp in my car but I am not certain which is the best way to power the thing.
    I know I need to have a common ground for my pc and the amp so that I get a minimum of noise but how about the +12V feed from the car-bat.
    The amp is a 4-channel(4*80W)...
    The car pc via M10000 with 60W regulated PS(only have 2.5HD + some usb-devices)...
    Shold I run a fused line from the car-bat to a distribution-block and feed the pc and the amp from that
    or should I use 2 different +12V-lines with separate fuses?
    Would be interesting to know the pros/cons(if there are any using the above methods)
    /L-O
    Jan 2003
    Ruston, LA
    I'd run a 4 gauge wire to a block and split from that.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Newbie pROJEKT vw zWO's Avatar
    Mar 2005
    South Africa
    yup frodo's ryt u could power the pc and the amp from a 4 guage cable but if u get voltage spikes u could use a Helix Power capacitor to balance things out. The remote lead of ur amp could cum 4rm the yellow 12v lead of 1 of ur hard drive power leads 4rm the power supply, it usually does it 4 me
    Carputer status:
    {=======---}70%
    Install status:
    {======----}60%
    Software status:
    {====------}40%
    I dunno why but it just worx sumhow
    Tainted Love Cris's Avatar
    Romania
    I have a power distribuitor in the back for the Opus and an amp for the front speakers, using a 8 .ga wire. Ofcourse that amp is 2x60W.
    Jun 2003
    Thanks guys!
    I think I will go for the distr-block option then...
    Mar 2005
    South Africa
    yup cool but just check if ur gettin voltage spikes(when the bass hits or wen u start ur car) b4 u blow sumthin. im sure itl b cool
    Carputer status:
    {=======---}70%
    Install status:
    {======----}60%
    Software status:
    {====------}40%
    Low Bitrate M11VNY's Avatar
    Aug 2004
    Leicester & Reading, UK
    yep id agree
    use a 4 gauge wire to a block and split from that.
    But.....Depends on what kind of setup you will go for in the future.
    If you want to put some decent subs which need more than 500w RMS to power them then you should use 4 gauge wire, if not then 8 gauge will prob be fine for a small 4 channel amp and pc.
    If you did want to upgrade ure system you could but a charging relay at the front and a separate battery in the boot to power pc and amp, this way you can run the system with the car off and no worries that the car won't start up after as your front battery won't be used.
    Its down!!!! Sold the Golf so took it out, it's still alive but not installed.
    Progress [-----------] 0%
    Who the Daddy Iz!
    Aug 2004
    You will probably be drawing at max 4x80 = 320W x 2 + 60W = 800W/13.8V = ~60A peak current draw.
    4GA handles 100-125A safely at 13-19ft cable length, so you should be fine with 4GA split out to 8GA as 8GA can handle 100-125A safely at 0-10ft cable length
    Better to overestimate your power needs than underestimate and create safety and unsatisfactory operational issues.
    If you are going to add a sub amp in the future, you might want to consider going with a 2GA or 1/0 GA instead.
    Mar 2005
    South Africa
    Iv had a problem with my system using a Helix monoblock powering 3 x 12" Helix subs & a 4 chanel helix subs running my splits but iv had probs when my car was idling the battery used 2 go flat while playing music. Iv run )guage wire throughout & 4guage to all devices
    Carputer status:
    {=======---}70%
    Install status:
    {======----}60%
    Software status:
    {====------}40%
    _
    Mar 2004
    Little Elm, Texas
    ghetto internet talk yo!
    lol
    disto block is your best bet - it will make things a lot easier....
    you can do what I did - which was to run your single power line from the battery - fused within 18 inches of the positive terminal of course, to a distrobution block that has fusing as well....that way you have double protection, which would be a good idea to do anyways. I have a 300 amp fuse up front, then a 20 amp fuse at the disto block for teh computer and 2 80amp fuses for the amplifiers.
    Jan Bennett
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. Dodge Ram 1500 (Hemi) carpc
    By pirate_king00 in forum General Hardware Discussion
    Last Post: 04-03-2005, 05:03 AM
  3. Replies: 20
    Last Post: 10-31-2004, 10:53 PM
  4. Sound not very loud have i bought the wrong amp
    By rickyaswell in forum Car Audio
    Last Post: 09-26-2004, 11:23 PM
  5. Those with a hu, amp, and carpc
    By falconey in forum Car Audio
    Last Post: 09-14-2004, 08:27 AM
