Results 1 to 10 of 13
Thread: ElevationAudio
    Mar 2005
    ElevationAudio
    any sq guys out there you have to check out the Elevationaudio.com website.
    just took out my Diamond D7 amp and repalced it with the smaller in size DX 80.4 by Elevation Audio and WOW that is all I can say.http://www.elevationaudio.com/dx804.htm
    _
    Mar 2004
    Little Elm, Texas
    the specs seem reasonably respectable
    I also appreciate the fact that they use the universal rating system (CEA2006)
    I'd like to see some more specs though...a lot more specs....since those specs that they give are pretty generic
    Jan Bennett
    Mar 2005
    what would you like red
    i'll see what I can do
    _
    Mar 2004
    Little Elm, Texas
    if you can find the full spec sheet that would be great....
    there's too much to list as to what I personally look for in an amplifier....
    for starters though:
    damping factor
    transient distortion
    THD%
    fusing (to know more about it's true power capabilities)
    stuff like that...
    a higher damping factor means that the amplifier can respond quicker to changes in music. Most amps run somewhere between 200 and 300 if they are decent. My Arcs run at 2000
    the important thing is that you are happy with it though. If you are, then that's ALL that should matter. =]
    Jan Bennett
    Mar 2005
    this is the best I can do right now
    thd .005
    fusing is 3 at 30 amps
    this is the best I can do.
    Newbie poseur's Avatar
    Mar 2005
    Yakima, WA, USA
    Those guts look an aweful lot like Avionixx-built products. If not made by them, they're atleast to a similar design. I'll see if I've got any pics floating around.
    Witherway I spose it's neither one way or another, I had some serious issues with avi-made tsunami amps, but the Avionixx-branded replacements are fairly decent for the money.
    Amd 2200+ athXPmobile, MSI KT6V-LSR mobo, Opus 150w, 512 ram, exterasys WIFI card, Hitachi 160gb, 3.5"hdd, bluetooth, Xenarc 700ts
    4/9/04: case roughed out and functional, hardware all together, finishing up bezel for screen, layingout wires, etc in car.
    _
    Mar 2004
    Little Elm, Texas
    those specs seem decent....but you never know till you hear it and get inside and feel it out...lol
    also, why did you start en entirely new thread about this?
    lol
    Jan Bennett
    Low Bitrate Blackrazor's Avatar
    Mar 2005
    Nelson, New Zealand
    Hehe, i know the manufacturer for those amps, same guys who make Crossfire and Kicker, Korean
    Not that thats a bad thing, the company makes some ruddy good amps. But, dear sir, they arent a patch on a D7
    Mar 2005
    Nelson, New Zealand
    Quote Originally Posted by vacguy
    thd .005
    How do you claim a THD of 0.005% and then say they are CEA-2006 compliant measurement? CEA-2006 is power output at 1%THD+N
    Mar 2005
    Nelson, New Zealand
    Quote Originally Posted by Red GTi VR6
    Nice... although most people cant pick the difference after a damping factor of 100 or so
    Just as a note too, the damping factor is on a heavily logarythmic scale, even tho 2,000 or even 20,000 sounds like a massively larger number than 200, the difference to the sound in practise is less than if you moved your head a centimetre in either direction. So while a high damping factor can be a sign that the amp is well made, dont expect to hear a difference unless you wear a neck brace while drivin
    If you want an interesting read, check out : http://www.audioholics.com/techtips/...pingfactor.php
