Have you grounded the computer case?
Can someone who's good w/ car stereo offer me some insight please?
I have my computer's sound card output hooked into my amp and it makes this buzzing noise that's really annoying at low volume levels. If i plug headphones into the computer, no noise. If I run an external cd player into the amp, no noise. If i add a ground loop isolator, it makes things worse. If i change the wires from the amp to the computer, it doesn't help. I have tried 2 differnt stereo to rca adatpers, and 2 sets of rca cables. I have re-routed them in various ways, and I have regrounded the amp elsewhere. HELP!?!
mATX mobo
2.4 GHz Celeron (prescott)
512 MB RAM
80 GB 3.5" HD
Runnin off an inverter (for now)
7" Lilliput
Microsoft (Pharos) USB GPS
Have yet to pull the trigger on a slim slot load DVD
STATUS: who knows... I don't
are you running power next to signal wires?
have you made SURE that you have a good ground? have you scraped away all the paint that was there?
are you using an inverter or a DC-DC psu?
Jan Bennett
One last time. Use a ground loop isolator.
http://www.radioshack.com/product.as...t%5Fid=270-054
If this is the one that you have already tried then I appolagize but I swear by this one. If you havnt tried this particular one, that would be my next step.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
The case is grounded. I have tried holding the rca cables from the computer to the amp in the air, that doesn't seem to stop the noise. The battery is in the trunk, so I didn't run a big power wire from the hood. I grounded the computer at the facotry ground for the battery, so I know that's good. I'm running an inverter, but I have one in my other car and I have installed them in lots of cars like this, but never heard this noise before. it's not just a whine, it's a buzzing sound, and it doesn't change w/ rpm's.
hrmmm - sound card?
amp going out?
does it get louder with the volume being turned up?
there's so many different things is could be...lol
Jan Bennett
n8scstm, might want to read a little more throughly next time?
Originally Posted by amrit50
Jan Bennett
Ground your PC audio to your HU audio.
I'm pretty sure that'll fix your problem.
"Ground your PC audio to your HU audio."
What does this mean?
If i must the pc volume the sound doesn't change, nor does changing the volume. The sound is on board on a new MB, and the amp is brand new too.
HU=head unitI don't have a head unit, just a lillput screen.
