Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Fan-cooled sub
  1. #11
    Mar 2005
    Once again, thanks for your answers!
    I've now been feeding my sub with some 50-150hz sinus-waves, and i can damn well hear when the amp starts to clip. Had a terrible headache the rest of the day after sitting in the car for about an hour listening to 240Watts of sqarewaves
    It's harder though to hear distortion in the bass-kicks, but I guess they don't produce that much heat since they have such a short period of time.
    I've been thinking about the low frequencies, like below 30hz (yes, I know you can't hear that in a car, unless it's very big ). Unless the sub bottoms out, shouldn't it cool down the sub extra, since it is below the resonance frequency and thus have a higher cone excursion?
  2. #12
    Mar 2005
    Ok here is the way i test my subs. And im no expert but i have been doing this a long time now. And i have 2 1000 watt rms subs. I picked up a bass testing cd at my local audio shop. It has a track that starts a very low frequency to a very high frequency and back down again. I turn my volume up to a level that is damn loud but wont hurt my component speakers. Then i pop in the test track and run it over and over until i start to hear the sub clip or distort and then turn down the gain on my amp and run it one more time to be sure. But i would suggest taking your sub and amp somewhere and getting it scoped properly if you are feeling uneasy about doing it yourself. And always remember the gain is not a volume control for your sub. It is a way to match the signal from the head unit with the signal going to the subs. Or so im told
  1. Hacking into Fan speed switch...
    By Dexter in forum Hardware Development
    Last Post: 07-12-2005, 11:11 AM
  2. Fan problems on my carpc
    By JohnChimpo in forum General Hardware Discussion
    Last Post: 12-10-2004, 08:25 AM
  3. LED Fan
    By EBFoxbat in forum General MP3Car Discussion
    Last Post: 11-11-2004, 03:46 AM
  4. Do you need a very compact graphic fan controller?
    By more mods in forum LCD/Display
    Last Post: 09-24-2004, 06:17 AM
  5. Case fan modified. Safe?
    By cafn8 in forum Off Topic
    Last Post: 03-18-2004, 10:57 AM
