Hi you car audio freaks! :)
First of all, I need to get one thing straight. I have a subwoofer rated 400W RMS/800W peak and a 240WRMS/480W peak rated amp. The Xmech on the sub is 48 mm. From what I've heard before, it is possible for me to pump up the gain om my amp too much, causing the amp to clip and overheat my subwoofer thermally. But I've also read on this forum that it it almost impossible to overheat the sub that way (man, all the different opinions is really confusing :tard: ). What is the real answer to all this?
From what I've heard, clipping an amp gives a DC voltage to the sub, making the cone movement different and the air-cooling work unproperly.
I've been thinking of installing a fan inside the sub box, blowing air into the coil. Then I should never have to worry about getting my subwoofer coil burned from amp-clipping (I know the fan will give a buzzing sound, but hey- it's not a THX-system anyway). What do you guys think about that idea?
