Results 1 to 10 of 13
Thread: Are distribution blocks bi-directional?
    May 2004
    I know its a strange question. Here is what I want to do. I have 4 ga running from battery and was looking at a block that has 1-4 ga in and 4-8 ga out. One of the 8's would go to the OPUS. I am hoping to take 2 additional 8's and run backwards through another block to get back to 4 ga for the amp. Will this work?
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    I am not quite sure what you are talking about (probably some kind of language barrier) but it seems to me like you are trying to invent... a perpetum mobile!
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    Yes it would work, but i would recommend it, it is definatly not the best method. why dont you just look for a block that has 4 gauge outs or run 8 gauge to the amp, what is the power rating of the amp?
    Signature: [==||========] 20% complete
    ddn
    ddn is offline
    Dec 2004
    Yes.
    P.S. Dumbest question ever?
    May 2004
    The amp is rated 4 x 80 RMS @ 4 ohms. Running 8 ga to the amp may be enough but why starve the amp if I can get additional power from the dist block with another 8 ga feed. I would assume that the reverse dist block idea would be safer than stuffing two 8 ga feeds into the amps input or trying to stuff 4 ga output into the dist block.
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    Quote Originally Posted by ficklerx
    You will not starve an amp that has that much power. 1 8 ga wire is perfect.
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by ddn
    don't be an ***, if he didn't know it's not a dumb question.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Low Bitrate Pepe's Avatar
    Jul 2003
    Kingston, Ontario, Canada
    Make sure you can actually fit a 4 gauge wire in the terminal on the amp. I know my amp was rated saying it only needed 8 gauge, and I wanted to run 4. So I mounted the amp, ran all the 4 gauge, and came to find out that 4 gauge wouldn't even fit in the + terminal of the amp.
    And I agree with lgbr... 8 gauge for that amp will not even come close to starving it.
    99 Ford Ranger - Bagged and laying frame
    Current Carputer project:
    Done:
    Custom mounted 7" LCD w/ TSK in radio bezel
    Custom center console for relocated headunit
    Via Epia M10000
    GPS
    MP3
    OPUS PSU
    DVD
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Quote Originally Posted by scott_fx
    Agreed. He asked nicely enough. No reason for useless flaming.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    Constant Bitrate mbuchman's Avatar
    Feb 2005
    If you keep the 8 gauge under 7 feet long after the distro block, it will allow for the same amount of power as the 4 gauge wire brings to the distrobution block.
    Your way would work too I guess, but I wouldnt recommend it.
    Dont forget to fuse after the distrobution block! (unless you have a fancy one with fuses already in )
    Matt
  1. Power Distribution?
    By Optikal in forum General Hardware Discussion
    Last Post: 03-23-2005, 11:11 AM
  2. video distribution?
    By hybrid racer in forum Newbie
    Last Post: 03-09-2005, 12:26 AM
  3. Distribution Block Questions
    By beckkl in forum Power Supplies
    Last Post: 10-20-2004, 11:29 AM
  4. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 04:59 PM
  5. Nothing but blocks on 4x40
    By fbwr75215 in forum LCD/Display
    Last Post: 07-24-2001, 09:37 AM
