Results 11 to 20 of 21
Thread: Could my amp be bad or did i miss something?
  1. #11
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    Quote Originally Posted by Stonewall78
    That wirring is definely not big enough for that much current if you are doing a long run (say more then 10ft). Never look at the fuses on an amp and guess that is how much current it draws, the fuses could be for all types of things etc I think the problem is the alternator is not able to keep up with the current demand and the amp is sensing the problem and shutting down rather then killing the car. I know from experiance with my friends 1000watt alpine that it can kill a running engine if idling. You have to make sure you have a solid charging system and battery before running that type of power. That is the price you pay, you have to make sure everything is up to snuff if you want the big numbers and 4ga won't cut it.
    4 gauge is definatly enough in this situation. Theres nothing wrong with looking at the fuses to see how much something could draw, its not going to tell you how much something will draw but its going to give you a maximum.
    Signature: [==||========] 20% complete
  2. #12
    Newbie Teknoledgi's Avatar
    Jan 2005
    Gold Coast Australia
    One point, have you upgraded the car shell ground to the battery negative, sometimes you can run a 4Ga ground to a good point on the body, but the body is only connected via old 10 or 12 guage to the battery negative
    Lilliput 8" Touchscreen LCD
    VIA EPIA MII-12000
    60GB 3.5" Hard Drive 5400
    512MB DDR PC2700
    DVD Drive
    802.11G Internal Wireless Card - External 5db Antenna
    100m USB Bluetooth Adapter
    Nokia N70 Phone
    GPS USB Receiver
    Centrafuse 1.6
  3. #13
    Low Bitrate code-'s Avatar
    May 2004
    Haugsund, Norway
    Quote Originally Posted by sansoo24
    I havent scratched the paint off yet but i have never had this sort of problem before. I'll try it though anything is worth a shot right now.
    Could it possibly be that the Cap is wired up backwards. Ya know positive on negative and visa versa? But i would think the cap and/or the amp wouldnt even power on then.
    Thats the problem right there, strange nobody reacted to this.
    The ground must be metal to metal, not metal to paint
    1984 BMW 323i (E30)
    [==========] 90%
    EPIA MII10000
    256MB RAM
    40GB 2,5" HD
    Lilliput 7" TS
    Hacked Travla C134
    Haicom CF GPS
  4. #14
    Mar 2005
    kansas
    Thanks a lot everybody who tried to help. Beleive it or not i tried almost every suggestion and nothing would get this thing to work. So i had to take it to a place that fixes and tests amps in my area and spend 50 bucks to have it tested and another 175 to get it repaired since its out of warranty. Sucks a phat one but even with the added cost i paid well under retail.
    Thanks again for all the help.
  5. #15
    May 2005
    Most amps will now go into protect mode if you do not have your ohms correct...make sure that this is the case...the other thing is that you could have a bad speaker somewhere...try them all out at a very low gain individualy and see if that works.
  6. #16
    Constant Bitrate accentsound's Avatar
    Jun 2005
    Jupiter!!!!!! FL.
    Your amp going into protect has nothing to do with power connections. So stop looking there.
    The protect circut protects the speaker outputs. You are having issues on the speaker end.
    This is typically due to a speaker / amp mismatch. or a blown sub.
    You need to know what ohm load your sub runs at. Single 1, 2, or 4 ohms.
    Dual 1, 2, or 4 ohms.
    Then you need to know what ohm load the amp is stable at. Most amps say if they are 2 ohm stable will go into protect if connected to a sub wired at 1 ohm. Competition amps are better at handleing reduced output loads but even there many will go into protect if pushed hard enough.
    My gut feeling is that your 6 channel is no more than 2 ohm stable and your sub is wired to a 1 ohm load. Hence the amp goes into protect. You use a ohm meter and measure across your speaker leads while disconnect from the amp. THis will verify things.
  7. #17
    Feb 2007
    hey everybody in here....my JL amp has the ohms light on....any body has a clue about what the problem is???
  8. #18
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Quote Originally Posted by JL_set View Post
    Ok, did you even do a search before asking this question? cause it could be about ANYTHING....
    How could we know what's wrong without ANY kind of info.....
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
  9. #19
    Jun 2005
    chicago, Illinois
    you were better off starting a new thread instead of trying to hijack another
    PROGRESS:
  10. #20
    Jun 2006
    Abele, Belgium
    ehm..... He did by now
    CLARION HX-D2
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
  3. Auto power off
    By accord in forum General Hardware Discussion
    Last Post: 08-15-2004, 08:08 AM
  4. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  5. amp +smoke = bad USUALLY
    By pcman_cortina in forum Off Topic
    Last Post: 07-09-2002, 04:20 AM
