there is no such connector, although it can be done,
wat you will end up with is a switch to flick between cd changer sound and pc sound
you must leave the CD changer plugged in as there needs to be a signal from the changer to the HU to let the HU know the changer is there in order to except sound,
what you do is strip down the chnager loom, and when you look at it there is 2 pairs of wires that are additionally sheathed off, these are your audio left and right, you need to wire in a switch and phono connector to switch between changer and PC
HTH
LinkBack URL
About LinkBacks
