Results 1 to 10 of 11
Thread: Sound Skipping!! Please help
    Oct 2004
    setup is a VIA M10000 w/ 512 DDR ram, 80 gig HDD, onboard soundcard, onboard video card.
    Problem is....after downloading about 100 music videos i noticed about half woudn't play correctly (audio fine / no video). Some of the files play with no issues at all but some files need a codec.
    so i installed PowerDVD and now they all play. Problem is the video plays but the audio is very choppy.
    This also happens when playing DVD Audio media. When playing the music with only audio... no problem. When playing the audio with the video, audio skips.
    What can the problem be? Seems like the bigger the file, the more likely it will skip.
    Oct 2004
    Thanks in advance to anyone who can troubleshoot this.
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    Many music videos are encoded in m2v format. This is also used for DVD's. The best decoder I've used is from elecard. Try that one. Also try WinDVD.
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    Oct 2004
    But, i used powerdvd on other computers and all the music videos played fine.
    Oct 2004
    thanks, ill try elecard
    Newbie coconut924's Avatar
    Oct 2002
    Riverside, CA
    I have the same problem with MP3's... Good ones, not rips. Downloads from itunes will skip even though they played perfect before. I also have an epia mII with onboard sound/video.
    1997/Honda/Civic HB
    Mar 2005
    kansas
    here is a little hint: ITS THE DAMNED 1GHZ CPU. Whens the last time you saw a decent computer use a 1ghz. IS the cpu getting really hot? Are you running a trimmed down vresion of Xp or Xp lite? Are unecessary processes running?
    There is a whole ton of things you could look at.
    Mar 2005
    The onboard video and audio are definately causing the problem. They just can't handle that kind of decoding. Try using an offboard sound card, usb or pci. That should isolate the processing enough to make your system struggle through it less
    Dave
    Oct 2004
    UPDATE:
    i updated my audio drivers from VIAs site and now things are better but not fixed.
    Before on some files where video and audio would skip, now the audio is fine but the video still skips.
    i should probably try a offboard video card.
    Oct 2002
    Riverside, CA
    CPU IS NOT HOT. RUNNING WIN2K. I HAVENT MODIFIED THE OS AT ALL. THE CPU IS RUNNING AT 15-20% AT MOST WITH iTUNES OR WINAMP. IT SEEMS LIKE THE SKIPPING IS GETTING PROGRESSIVLY WORSE.
    I AM DEFRAGING THE HD TO SEE IF THAT WILL TAKE CARE OF THE PROBLEM. MOST OF MY SONGS ARE CD QUALITY WAV FILES BUT MP3'S SKIP TOO. AND THE DRIVE WAS FRAGGED REALLY BAD.
    AND IT NEVER DID THIS UNTIL I PUT THE COMPUTER IN THE CAR.
    1997/Honda/Civic HB
  1. Weird sound skipping in winamp (VIA EPIA 800)
    By bayere in forum General Hardware Discussion
    Last Post: 09-08-2004, 08:35 AM
  2. Sound cards from incarpcs , sacrificing sound quality?
    By skinhead in forum General Hardware Discussion
    Last Post: 09-02-2004, 03:05 AM
  3. Best possible sound quality
    By ST43LTH in forum General Hardware Discussion
    Last Post: 07-06-2004, 09:10 AM
  4. Wanted: Clean sound from carpc
    By slushieken in forum Car Audio
    Last Post: 06-20-2004, 10:17 AM
  5. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
