Results 1 to 6 of 6
Thread: Power cables, where to get cheap.
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Im gona do a dual battery setup, and i was wondering where i can get cheap 2-4 Guage power wire.
    What guage do you think i should use? im gona be running from under the hood to the rear of the car. should i use 2 GU?
    The Guy at Pepboys said home depot. but i dont know.
    Also what isolater is good?
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    hey use 0guage under the car wire tired to the body becasue 0 guage is hella thick to run inside... hope it helpd :-P
    Quote Originally Posted by xdjxklusivex
    Really? i wont be pushing more then 80 amps from the alternator since the Isolator im looking at is only 80 amps, so you really think i need 0 Guage?
    1990 Jeep Cherokee
    Constant Bitrate mbuchman's Avatar
    Feb 2005
    I think you will want to go with 0 for 80 amps. The reason for this is because how large of a stretch it is. If you only needed 10 feet of wire, 4 would do it, but I figured it at 18, and came up with 0 gauge. And dont run it under the car... do it the right way (under carpet).
    http://knukonceptz.com is a good place to get wire
    Welding stores apparently sell the wire cheaper, but I really dont think its as nice as the Knu stuff (flexibility is really nice when installing, and I dont know how well the welding cable would flex)
    Matt
    Mar 2005
    Here is a link to a VERY cheap place to buy heavy wire. Welding cable is perfectly fine for power requirements, and is cheap enough where you can actually get enough cable for any power you might be running. I think I'll be running a couple shots of 4/0 gauge :P Now I just gotta make some connectors for it...
    Go to the bottom of this page for welding cable.
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    i would use 4 gauge, 80 amps is fine on 4 gauge cable up to well over 20 feet
    Signature: [==||========] 20% complete
  1. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 01:08 AM
  2. Low power alarm, kind of
    By System-f in forum Power Supplies
    Last Post: 03-11-2005, 01:48 PM
  3. Power inverter cables
    By CJ8501 in forum Power Supplies
    Last Post: 10-11-2004, 11:18 PM
  4. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
  5. HD power cables...?
    By lina in forum General Hardware Discussion
    Last Post: 05-06-2000, 10:28 AM
