Results 1 to 10 of 13
Thread: Question regarding FM modulators
    Dec 2003
    South West, FL
    I know there has been alot of disscussion in the past about these but I wanted to ask a quick question
    I have heard FM modulators are not that good due to the fact that you will still get dominant radio waves trying to cut into your music.
    However a friend of mine says that FM modulators that have a antenna hookup will make it so that when you are playing your music the antenna will be cut off and no more FM waves will be present to interfere with your signal.
    Can anyone validate this or back this up as my knowledge of car audio is pretty nill.
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    Quote Originally Posted by Scorpnstail
    The inline FM modulator that I've bought just recently contains a relay which indeed cuts the link from the car antenna to the HU as soon as 12V power is applied. I haven't tried it yet, so I have no idea about the overall sound quality. If it turns out to be really bad, I think I will sacrifice my cd changer and get an AUX-adapter from www.connects2.com.
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    My personal experience, wireless ones are pointless. Around here anyway (Boston). Every one I've tried had a strong signal on all of the available channels. I ended up with a inline Kenwood one that works perfectly. I don't believe they make it anymore though.
    Jan 2004
    Fort Lauderdale, FL
    Even the inline modulators let stonger interferance in. FM Modulators are not the way to go if you want good quality input. I learned the hard way....
    Apr 2005
    Boston, MA
    Quote Originally Posted by cd25987
    For me, so far so good. Though outside of replacing my HU or amp, it was my only option I could get working. I'm happy with my setup so I didn't want to replace it just to use my nomad.
    Dec 2003
    South West, FL
    Yea .. that is what I am refering to ( Inline modulators )
    How would it be possilbe for something to get though if you basicly block the FM signal from ant. ?
    Feb 2004
    Green Bay, WI
    I have one for sale if anyone is interested...pm me...
    mox
    mox is offline
    Nov 2004
    The Netherlands
    The modulator sits inbetween the outside aerial and the HU. Once power is applied, the aerial gets disconnected from the modulator so radio stations cannot interfere with the signal coming from the modulator (hopefully...).
    Think of the modulator as a normal FM radio station with its own fixed frequency.
    Software: RR, MM/FD
    Dec 2003
    South West, FL
    Quote Originally Posted by mox
    thanks for explaining that .. I did understand how it worked but I was curious on if the aerial is disconnected how can any other signal other then the one from the FM modulator get through.
    mox
    mox is offline
    Nov 2004
    The Netherlands
    It can't You are supposed to turn the modulator off if you want to listen to normal radio stations. It stops "transmitting" and the relay restores connection between antenna and HU.
    Software: RR, MM/FD
  1. TV FM Tuner Driver Question
    By doctorr in forum General Hardware Discussion
    Last Post: 08-02-2005, 02:16 AM
  2. FM Modulator Question
    By frenchbluefocus in forum Newbie
    Last Post: 11-24-2004, 12:05 PM
  3. Very cool FM transmitter and easy wiring question
    By wompser in forum General Hardware Discussion
    Last Post: 04-24-2004, 05:11 PM
  4. Consenus on quality Power Inverters and FM Modulators
    By dodgetimes2 in forum General Hardware Discussion
    Last Post: 04-14-2004, 09:21 AM
  5. {Aus} FM Modulators
    By eminence in forum General Hardware Discussion
    Last Post: 11-02-2003, 11:20 PM
