Page 4 of 12 FirstFirst 123456789101112 LastLast
Results 31 to 40 of 120
Thread: Has any one used Performance Teknique ICBM 5.1 amp?
  1. #31
    Nov 2005
    Quote Originally Posted by debugger View Post
    Everything digital is contolled from the remote which comes with it, you need to connect it to your screen using coaxial RCA, so u can see all the settings on the monitor, just like setting up the VCR or DVD player.
    1.) Yes ofcourse there are no problem setting this unit up when first installed to tune it in. When I installed my previous standard hifi-system in my car I tuned it in, closed the trunk and of I went. The rest was adjusted from the headunit for day to day use. Since I have the touchscreen to change song, volume, switching modes etcetera it would be annoying to have an additional remote to use for basic adjustments like volume or to select sources when driving. I assume this is not the case, but if it is I´ll rather go with a non-digital amp that doesnt require this.
    2.) If I have optical out on my soundcard I dont see why I have to have any other cables connected to the amp from my carpc and not why I have to select between sources on the amp...
    Black SolarCell Portable Bluetooth Gps reciever for sale, Contact me!
    BMW E46 320 Touring project thread, making the perfect multimedia car ;)
    BMW E46 WORKLOG
  2. #32
    Variable Bitrate debugger's Avatar
    Mar 2006
    CA
    Quote Originally Posted by bimmerpc View Post
    Switching sources can be achive through using ACC and Remote in turn on leads. Check the manual to see how everything works, but you do need to hook up the remote first in order to switch to SPDIF or RCA-D input initially. I haven't recieved my remote control with my amp, still waiting for it to arrive then I'll be able to tell you more how it works out, and for now I'm just following the manual that I got with the amp to explain. So I can't be 100% sure if this particular does really work as described in that manual.
    The main point is that it should switch the inputs automatically for you once you have everything setup. Once I've test everything out myself I make a new topic on PT 5.1 amp, with pros and cons and all the details on how to set everything up the right way.
  3. #33
    Newbie 3D Warrior's Avatar
    May 2006
    Welland, ON
    do they make them in like 4.1? or something like that?
    how do you guys have it set up?
    i mean i got 4 speakers... 2 front 2 back and 2 12" subs in the trunk... "soon" will have the pc running in there... what's the best bet to get most out of the sound card and the amp(s?) and the speakers?
    Cheers...
  4. #34
    Mar 2006
    CA
    Quote Originally Posted by 3D Warrior View Post
    Cheers...
    ICBM 5.1 supports pseudo surround mode 4.1 (center channel gets split between front two)
  5. #35
    May 2006
    Welland, ON
    Right! why didn't i think of that... Thanks man!
  6. #36
    Nov 2005
    Can someone confirm that this amp can be wired to the cars ignition or any kind of wired remote on/off so that I can integrate it to the push-button I press when I want to turn on the computer?
    BMW E46 WORKLOG
  7. #37
    Mar 2006
    CA
    Your power supply probably has REMote amp turn on lead, just use that, this amp is not any different than other amps except for that instead of 1 remote turn on connector it has 2 of them "ACC" - connects to ignition +, and "REM" - remote turn on. The reason why it has 2, is that when you play lets say only your cd player, you run the remote turn on from that cd player to ACC, so the amp will turn on and go into analog mode without the use of its on board decoder. Then if you have a DVD player thats connected to the amp throught the optical cable, you run the remote turn on from it to "REM" connector on the amp, so when you turn that DVD player on the amp goes into digital mode (decoder is on). So you just have to figure out the way to connect it to the computer onboard sound card. I use both RCA analog and SPDIF toslink, so you can just wire a flip switch to send a + signal to "REM" or use the remote to switch on the decoder.
  8. #38
    Variable Bitrate jschrauwen's Avatar
    Jul 2006
    Frankford, Ontario, Canada
    Cheers...
    Center Speaker ON/OFF Switch Using Phantom listening Mode
    From previous page - http://csexpo.stores.yahoo.net/icpete51hipo.html
    http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
    1990 RHD JDM 300ZX TT 2+2 5sp T-Top
    491RWHP / 18psi / 94 octane
  9. #39
    Nov 2005
    Has anyone found any reviews on this amp?
    I cant find any and the prices on this amp is always "on sale" or reduced so I guess it´s a bad performing one, correct?
    My local shop didnt think that with that price and specs, would be any kind of quality inside and that I would get disapointed
    BMW E46 WORKLOG
  10. #40
    Mar 2006
    CA
    I don't think you gonna get disappointed its worth the money i think!
  1. Hifonics Zeus AMP for DIGITAL 5.1 decoding!!!
    By kenski in forum Car Audio
    Last Post: 04-22-2010, 04:27 PM
  2. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  3. 4 to 6 channel amp recomendation for 5.1 DD
    By antimatter in forum Car Audio
    Last Post: 09-23-2006, 07:44 PM
  4. Altec Lansing 5.1 Amp Messed Up, Need Help!
    By nFiniteTuning in forum General Hardware Discussion
    Last Post: 03-19-2005, 08:08 PM
  5. M10000 5.1 through 6 channel amp?
    By fly_dutchie in forum Car Audio
    Last Post: 05-15-2004, 03:28 AM
