Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
Thread: Toyota Graphic equalizer 1701
  1. #31
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    肚子笑痛了
    S60 Install
  2. #32
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Scouse Monkey
    haha i knew you would ask that! Walky talky - Boris has you now!!!!
    </thread jack>
  3. #33
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Lol. I mean the circular connector that went inbetween the headunit and eq is digital. The actual audio lines from the headunit to the eq, then out to the speakers are of course analog. I dont think I need to even use that connector at all, I think its just for headunit control of the EQ maybe? I'm trying to find an old headunit I used to have laying around, and hook it up to a pc psu and an extra set of speakers, see if it works lol
    RevFE
    My Shop
  4. #34
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    i found a stock eq that looks like that in a 1983 Toyota Cressida
    http://memimage.cardomain.net/member...589_3_full.jpg
    now they are the same basiclly but this 1 has builtin amp with it.
    but looking at it your eq lights up between the metal levers so it would have the cool light on each lever
    You might want to see what a stock eq without amp looks like you might find it's that car or atleast around that year
    EDIT:
    I attached the pic u posted and brightened it up for everyone else to see where the LED/lights are
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  5. #35
    Aug 2004
    Ok some more info
    Toyota oem package Premium tape plyer early 80's model 5 presets am/fm dolby Model 1622
    Usually came with 7 band equalizer model number 1701
    Well early 80's it is
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  6. #36
    Feb 2011
    Holy Thread Resurrection!
    First of all, I realize this thread is about 6 years old, and no good will probably come of this. To the original poster: If you still care, I can provide you with a pinout and the purpose of each wire coming off the back of the EQ. You would basically remover the harness from the EQ, and splice it into the outputs of your existing stereo. I have the same 1622 tape deck and 1701 EQ combo, but I am missing the part of the harness you would discard in your installation. If you still have the EQ, I would happily send you a check for the harness and enough wire left on it to splice onto. Also, if anyone else would have one, or know where to obtain one, please email me at [email protected] . To reiterate, I do not need the "wires from the stereo-to-existing vehicle harness." I do need the "part that clips into the stereo-to-the loose wires." Thank you for you help! -Jon
  1. Finally, 2004 Toyota MatrixPC is ready for primetime
    By MatrixPC in forum Show off your project
    Last Post: 11-28-2009, 05:50 PM
  2. equalizer
    By psych0sys in forum Software & Software Development
    Last Post: 03-25-2008, 08:25 PM
  3. Toyota MK3 Supra Turbo SportRoof installed
    Last Post: 10-09-2007, 11:26 AM
  4. NewQ Platinum PC Audio Graphic Equalizer
    By Joshua in forum Classified Archive
    Last Post: 12-14-2001, 06:52 PM
  5. Aux. input adapter vs equalizer
    By Dima in forum General Hardware Discussion
    Last Post: 09-13-2000, 11:46 AM
