Results 1 to 10 of 17
Thread: Optima Battery survive crank
    Constant Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    Hi all,
    Thanks for Looking
    I was wondering if anyone knows will an Optima Battery or similar type battery help survive crank? Or it will not help at all?
    I need to get a new battery for my car because of the old batteries age and because of my stereo system anyway so I was thinking maybe of getting a Optima Battery or similar type battery if it would help survive crank.
    It will be the only battery in the car.
    I am using an inverter.
    Or Will I still need CarPC Tank EZ v1.0 - The Simple Tank or similar device?
    Thanks for your advice
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    It depends what you are using to power your PC. I have a 4 year old crappy battery and my 300W belkin inverter survives crank fine, not even causing trouble to a booting or playing divX laptop with the battery removed with the headlights and stereo on (a 'worse possible scenario' test i ran to check for cranking issues)
    Registered User Dudes99's Avatar
    Dec 2004
    Norfolk, Va
    umm, does your inverter power off when you crank currently? Try testing it with some sort of similiar load on it.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    yes it will help. I had an opus 90w and still couldn't survive crank untill i upgraded the wiring to 8gauge and put in the yellowtop. I am using it as the only battery in my car for about 1 year now with no problems
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    what type of inverter? An inverters abililty to survive crank is pretty much dependant on its wattage and how you have it connected. A yellow/red top should certainly help but only if the inverter is connected directly to the battery and properly grounded. I own a yellow top and i've never had my inverter fall flat during crank.
    Feb 2005
    Huntsville, AL
    thanks for all your help
    I am using a 700 watt inverter not sure what brand?
    which will not survive crank...
    using a shuttle pc amd 2400 thoroughbred chip
    1 usb port being used.
    2 serial ports being used
    512 ram
    WD 250 GB Hard Drive
    I had a cobra 400 watt inverter lying around just tried that out and it survives crank every time ( tried about 20 times all in about 5 minute time) but maybe 1 out of 7 times when I shut the car off it shuts down for a second just enough to reboot the PC.
    maybe it will be ok if i do not turn on and off the car like i did to test it?
    maybe in the real world it will be better?
    what you think?
    The inverter is conected straight to the battery.It is not on switched ignition.
    on the cobra inverter I had a volt meter on it with the car off and inverter off (just to test voltage in trunk from battery in front) it was about 12.5v. and with the inverter and pc running with the car off it was about 11.50v with the car started with inverter and pc running it was about 13.5v.
    that is with using only 14 ga power wire from battery to trunk.
    I think it might be time to upgrade wire to 8 ga or 6 ga?
    could I use the 1/0 power cable running to my amps?
    or am I going to have problems using the same wire?
    1/0 cable is for 1 Orion 2500d amp pushing 2 orion 12" h2 subs. and 1 Orion 800x4 amp for the 2 sets of orion P-SERIES components.
    would the 1/0 cable be able to handle the extra wattage from the inverter and PC?
    Thanks for all your help.
    Feb 2005
    Huntsville, AL
    I still Don't understand why the cobra inverter will kill the PC when I turn off the car (sometimes not all the time).when the inverter is conected straight to the battery it seems like it should not mater if i turn off the car but it does survive crank every time.
    The other inverter never had a problem when I shut off the car but it would never survive crank.
    Its like my problem just reversed itself when i switched inverters.
    any sugestions?
    Low Bitrate khemical's Avatar
    Jun 2004
    DeKalb
    Quote Originally Posted by Sonicxtacy02
    Red = bad, just stick to Blue/Yellow tops (yellow being the more common for car audio, blue has more crank amps)
    steven n
    95 Saturn SC1
    Alpine 9831 + Blaupunkt SR04
    Stereo Integrity 327 Comps + MTX 4244
    Resonant Engineering XXX 18 D2 + Elemental Designs Nine.1 + 7.5ft^3 tuned to ~29Hz
    Carputer Progress: Rethinking, box has consumed my trunk
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Red is good for starting engine, yellow is good for electronics.
    I have both connected as one big battery right now.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Dec 2004
    Norfolk, Va
    Michael, I would thnk that the 400 watt inv would work for that system wouldn't it? Have you tried that set up?
  1. Optima redtop battery
    By hannibal in forum Power Supplies
    Last Post: 04-02-2005, 02:09 PM
  2. Using a high farad cap to survive engine crank
    By lakorai in forum Power Supplies
    Last Post: 03-28-2005, 10:47 AM
  3. VERY nice Optima battery cage/hold down...
    By RedGTiVR6 in forum Classified Archive
    Last Post: 01-18-2005, 08:15 AM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  5. Woohoo I survive the CRANK
    By Squiddy in forum Power Supplies
    Last Post: 08-31-2004, 01:31 PM
