I would have the playstation running into the in car computer, rather than to the line driver directly. you can use the line in port. I wouldnt want hte ability to run both sources at the same time, so to speak.
Line drivers are available for a reasonable price that have multiple outputs, this would let you run individual lines to each amplifier. However, on a budget, I prefer to use splitters to pre amp outs, to prevent problems with the voltage level of your subwoofer amplifier preamp outs. some amps will control the level of the preamp outs via the gain, some dont. But you can be fairly sure the line driver will do nothing for you for the second amp, using the preamp outs. its usually bumped back down to a different line level voltage. again, depending on the amp. but you can prevent any possibility of a problem by just using a splitter.
LinkBack URL
About LinkBacks
