the best thing to do is to get an occilioscope and set the amps up that way if the siginal comes up square it is clipping if the siginal is sent in a wave patteren it is good. another option is using a multi meter you can call the manufacture and ask them if they know what output voltage the amp starts to clip at set the multi meter to ac and match your gains to that this technique isnt as reliable as the first. also when doing this you should use a test track that is recorded a +/- 0db with all loudness, bbe, or other like features turned off and volume set roughly 3/4 way up. just remember to unplug the speaker wires from the amp. hope I was of some assistance
Aron
LinkBack URL
About LinkBacks
