IMHO, If you can hear the difference between .85 and .9 cubic feet you are amazing. Take it from an installer who has built hundreds of custom subwoofer enclosures..... Get it close and it will work fine. If you were really picky you would need to subtract the volume of the driver from the internal box volume. The volume of the port should be subtracted from ported enclosures also. With sealed boxes you have a good 10-20% tolerance larger or smaller and still get good performance. I usually use a larger enclosure then the manufacturers recommend. I like to build a box for a Q of about .8-.9 for a car where some manfucturers go with a Q of 1.0-1.3 The smaller, higher Q enclosures give an f3 that is too high and the sub sounds too punchy with no bottom end. 3/4" mdf and internal bracing makes for a nice box. I found some stuff called ultralight mdf that is just as dense as regular mdf but weighs 1/2 as much. It's great for high performance vehicles. To figure box volume the formula is: LxWxH/1728 (in inches, and those are internal measurements)
LinkBack URL
About LinkBacks
