That would work, but odds are you would only need 1 amp for the 2 subs, unless you have some massive sub that I have never heard of before.
You can either split the line to go to all the amps (if your sound card only has L&R outs), or if you have a sound card with x.1 out, then you have no problem. The amp will have the cutoff frequencies so you will not damage your sub.
Make sure to get a class D amp for your subs, by the way.
Matt
LinkBack URL
About LinkBacks
