mainstream: kicker, precision power, phoenix gold, jl audio, memphis, directed, soundstream
high end: zapco, us amps, arc audio
i would buy any of these amps.
if i had the money i would get zapco.
Been planning for about a year.. about to finally start.
Ditching optical (no real good amps and too many other mini problems)
Setup is:
Maudio rev 5.1 going to (insert amp here ) then to
ADS 235is tweaters w/ JL audio XR series 5.25in woffers
already have a JL e1200 to JL 10w3v2
XR series woofers:
Recommended Amp Power: 25 - 125 Watts
Efficiency: 89.5 dB @ 1W/1m
Frequency Response: 53 Hz - 25 KHz ± 3 dB
Let me hear what you guys think!
Rick
Mobile Celeron 1.6GHz 30W,ASUS P4S800-MX, Audigy 2, Kingston DDR266 256MB
i was looking at a JL 450/4, why is the rear less powered than the fronts?
so the front will prob be louder? or ??
yes, because the front should be more pronounced then the rear. the 450/4 is also a good amp to use in a 5.1 setup, bridgeing the rear will give 150 to use for the center.Originally Posted by tdevil
TDEVIL: you could also use the e4300 then your amps would match as well
