Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Upgrades, which first.
    Mar 2005
    Question Upgrades, which first.
    I just got a 94 Explorer Limited. As far as I can tell everything in it is stock except the head unit, it's a Kenwood deck, can't recall the exact model number. The stock stereo was the "Premium" model with the factory sub in the rear cargo area.
    I'm going to install a carputer in the near future. I've been reading lots and have learned a few things. I've got a bid in on a service manual for my truck so I'll be doing as much of the work as I can on my own.
    Now, the question that I have is which should I upgrade first assuming that I can only afford one or the other right now. New speakers or install an amp? The kenwood HU puts out 4 x 50 watts. The factory sub/amp is in the back and sounds like it's still working and I'd like to keep that until I can afford to replace that as well.
    And I already did and the manual on for the kenwood deck.
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    Amplifier. You don't want to underpower any speakers.
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    both - you dont want to blow up your puny stock speakers and that 50w a channel is only max power, youd be lucky if thats 20w rms
    Constant Bitrate mbuchman's Avatar
    Feb 2005
    The way I look at it is you want to do whatever takes the most work first. Like when I get my next car, I will be doing wires and deadening first, along with the door and rear speakers (which will be a good $1,000 for the items listed above), and then when I can afford to put the amps, carputer, and head unit in, itll be plug and play.
    So with that said, do the speakers first, because its the most work.
    Matt
    Jun 2004
    Bay Area, California
    the way I see it, I rank everything I could do to my car in how much benefit itll actually improve the fidelity of my sound. I'm sure in your own car, purchasing an EQ is pretty low on the list of things to do!
    So if I were in your shoes, I would purchase speakers first.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    speakers first, no questions about it.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2005
    Ok, so I'm going to install new speakers shortly.
    But that brings a new question, do I need to replace the wire from the HU to the speaker as well, or can I just reuse the existing wiring?
    1994 Explorer Limited 4 Dr 4X4
    Still in planning stages.
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    mah, I noticed a big difference with the stock speakers, adding ad amplifier. forget your 50*4w, if you try to check the power drawn by your HU under load you'll probably see not more than 2 amps, roughly 25w. Obviusly you have to split these 25W for each channel... this speaks for all
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Constant Bitrate seanshine's Avatar
    May 2004
    Behind the Zion Curtain
    Quote Originally Posted by Corvin
    Depends on if you want to sell the vehicle sometime in the future.....if you run new speaker wires alongside your stock ones,it makes it easy to reinstall your stock speakers.
    Hopefully,whoever installed the head unit used a harness adapter,so you could reinstall the stock radio as well.
    Any sufficiently advanced technology is indistinguishable from magic - Arthur C. Clarke
    Jun 2004
    I wouldnt bother at this time adding new wiring. Despite what some people may say here, you can run a true 50 watt amplifier through your stock wiring. 50 watts to each corner just fine. In fact, shops do it all the time! faster to reuse stock wiring rather than rewire the vehicle from scratch.
    do you plan to run a 100x4 amp in your car? Id probably think about rewiring the car. 50 watt four channel amp? youll be fine reusing your stock wiring.
    oooooooooooooooooooooooooooorrrr
    feel free to rewire your car. but theres no point as long as you are running off deck power, for sure. When you buy your amplifier, and have to have the car torn apart anyways to run power wire and RCA cabling, THATS the time I would consider rewiring the car
    why have your car apart twice if you dont need to?
  1. Destinator (PC) v2 to v3 Upgrades
    By ukchris in forum GPS
    Last Post: 07-16-2005, 02:33 PM
  2. Need help for upgrades
    By Tower in forum General Hardware Discussion
    Last Post: 03-08-2005, 05:17 PM
  3. Navigator Upgrades
    By Trebor in forum GPS
    Last Post: 08-19-2004, 10:02 AM
  4. Clarion Autopc Needs Upgrades
    By ROCKROKA in forum General Hardware Discussion
    Last Post: 08-05-2004, 02:43 AM
  5. Copilot 2002 software upgrades?
    By SuperMatty in forum Software & Software Development
    Last Post: 07-02-2002, 10:54 AM
