Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Amp overheating?
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Amp overheating?
    I was driving home yesterday and the amp started cutting out. so since it only did it a few times no big deal. so today, i was driving for 30 min and it started doing it all the time like when i hit a bump, accelerate when i got home it was verry hot to the touch.
    would it be over heating? Kenwood is designed bad since the fan is on top
    Why would it just start doing it now? ive been using it this way for 4 months.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    check your ground... Bad ground can cause it to overheat.
    Jan 2004
    Jersey/NY
    or perhaps a lose power connection even... the bumps and whatnot can cause it to become loose..
    and perhaps the constant disconnect->connect->disconnect behavior may cause it to heat up a lot? I dunno, just a guess.
    Both power and ground are tight, it seems to run fine when im not moving or hitting bumps. i was just abot to get it work stiting still. but if i bump in my seat it cuts out.
    Oh yea, i felt it like a hour after i got home and it was still warm.
    1990 Jeep Cherokee
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    I suspect something internal.
    Kenwood makes good speakers, but their amplifiers are awful. They count the heat into the wattage. If the problem never fixes, get yourself a new amplifier.
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    May 2003
    Florida
    check out the rca's.
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    check everything! I had a problem recently, couldnt figure it out, every time I went over 1/3rd volume it would cut out, clip in and out- I could wiggle stuff and sometimes it would come on, slam the door somtimes worked - looking at the amp the overload protection light came on whenever it went off...this is a setup thats been fine for over a year..... anyway after tracing it through it was the little terminal board with the 2 connectors that sit on the speaker had fallen off and was intermittently touching the chassis - would never have figured it unless i traced it though- crap job but ya gotta do it.
    Quote Originally Posted by lgbr
    Yea, Maybe ill ebay it "as is" and buy a diferent brand.
    do you knwo any small 4ch amps that i could fit under the seat.
    1990 Jeep Cherokee
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    Are you bridging any channels? THe ohm load may be too low for your amp. But if it just turns off and not fries, its not a truly HORRIBLE amp, cuz some amps when you wire em wrong dont even save themselves, they go BZZZZT and smoke comes out.
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
    Aug 2004
    Floreeda
    The ohm load may be too low for your amp. But if it just turns off and not fries, its not a truly HORRIBLE amp, cuz some amps when you wire em wrong dont even save themselves, they go BZZZZT and smoke comes out.
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Could my amp be bad or did i miss something?
    By sansoo24 in forum Car Audio
    Last Post: 03-05-2007, 02:45 AM
  3. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
  4. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  5. I think my amp is overheating....
    By Gutter in forum General Hardware Discussion
    Last Post: 06-05-2002, 11:49 AM
