In my new car, I am going to be running two amps (not at first) plus the carputer.
I will be running two Alpine amps: 4 channel amp + sub amp. Both amps require 8 gauge power and ground.
In trying to hook everything up, I was looking to run 4 gauge power directly from an yellowtop Optima battery into a distribution block (which one?)
and then from there split it three ways to the amps and pc
As I said before the amps will be bought in stages, so far now I want to lay the foundation for everything and do it right from the beginning.
2005 Black Chevy Impala
I think this is what I need for two amps and the PC:
http://www.crutchfield.com/S-WD3ZZyr...15&I=211CBR44A
Would this work?
Why not look on ebay?Originally Posted by Shelbrain
Would any of thise blocks work? I wasi thinking the other product because it would make grounded the amps and the PC to the same point easy.Originally Posted by 0l33l
Don't use a block on the ground. You want to use a star ground. Bad grounding methods are the cause of 90% of noise in systems.
why can't you use a block? ... if I'm not mistaken, connecting all grounds together and then a single cable from that point to the chasis is one form of star grounding ... with this method using a non fused distro block establishes just that.
I certainly wouldn't recommend using a fused block for ground ... but I don't see any problem with using a non fused block.
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
Don't waste your money on a fancy distro block. Head down to your local electronics shop (in australia we have something like jaycar.com.au) and grab a 3 or 4 way fused distro block. Just make sure it is 4ag in and 8ag out. Chuck in fuses appropriate to the equipment and you're all set.
Probably a waste at 80bucks (US!) for something that is just a chunk of metal with some fuse holders and a bit of insulation.
I gave the crutchfield link only becuase they have large pics and detailed info about their products. I have a distro block for power, but I don't use one for the ground. I just have them all bolted in one place...![]()
If your looking for a cheap way out just get a 3 way 4 gauge block,And yes using a solid block for the ground is a very good idea.
2-15" ILO lcd w/DVI
6800 gt Duel DVI out
p4 1.6ghz flex atx board
1gb 400 ram
120gb(2-60gb raid) sata hd
2-60gb hotswap
WIN2K Pro SP2
M.A.M.E. w/2,300 games
CARPuter info
