Results 1 to 8 of 8
Thread: New sound system soon, need some help.
    Newbie beezm's Avatar
    Apr 2005
    Question New sound system soon, need some help.
    Alright guys, I recently posted here, got a little advice. This is what I decided on doing:
    Pioneer 37000MP Head Unit [Already Ordered]
    Pioneer 5.25" 2-Way's for front doors
    Pioneer 6.50" 3-Way's for rear deck
    I gave up on trying to find good bass producing speakers. I am just going to go ahead and get an amp and sub. This is really what I need the help on. I am pretty much so made up on what I wanna get, but I'm making sure it'll do fine w/you guys first =)
    (2) 12" Blaupunkt TSw1200
    Speakers are rated at 200W RMS/600W Peak each.
    Boss Riot 850
    Amp is rated at 425 RMS x 1 @ 2 ohms, so it'll be around 212W RMS going to each sub, which should be just about perfect.
    I have been working on nmy box plans for about the last hour or so, I'll post em as soon as I'm done drawing them up on the computer =)
    I'm also still debating if I should build a Bandpass enclosure, or save myself the trouble and build just simple Ported enclosures. Will the bandpass make that much of a difference on performance ?
    Please any suggestions or comments on this setup. The Blaupunkt's I can get for a great deal, that's why I'm going with them. I'm looking for some nice booming bass, not too worried about people hearing it from 2mi away >.<, but if that happens no complains ;D lol
    Thanks.
    - Stewart
    - BeeZm
    2000 Mitsubishi Mirage 1.8L DE Sedan
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    boss equipment is generally garbage...but the reviews looked somewhat promising.
    just build a ported box. bandpass has to be perfect or else it'll sound like ***.
    rebuilding carpc... kinda..
    Apr 2005
    Alright, yea I gathered that also from a few different reviews that the amp should be fine.
    Also... Here are the plans to my box that I plan on building. Any ideas on improvements ? and if anyone could check my math that'd be great =)
    - BeeZm
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    get a 10 inch jl w7 with a 500/1 amp and ull have more then enuf for bass if u got a small car
    Constant Bitrate mbuchman's Avatar
    Feb 2005
    Quote Originally Posted by xdjxklusivex
    Then he may as well also get an Eclipse deck, and Rainbo comps (or Boston if he cant find the Rainbows), and no cheaper than a PPI amp for sure...
    A good suggestion would be something like a lower line RE or Adire sub, or maybe some RF subs in a ported box (not the best, but probably a little better).
    Your dimensions do not include displacement of sub OR displacement of port, and I assume not wall thickness either. Wont change the overall response much, but just letting you know. And 2 inches is VERY small for a diameter of a port. If you just have a lot of 2" pipe, then go with 4 or so, and bump the tuneing frequency to 35 rather than 30hz (35 is typical anyway). That would give you 11.81" long ports, which would fit perfectly without needing a bend (remember about 3" clearance from back of box).
    I didnt bother with any of the specs, so I dont know what the vent mach will be, but I would personally go with a 6" diameter port, and tune to 35, which would make it 25.47" long (need an elbo then), or maybe a 4" diameter port tuned to 35 might work (10.34" long). I assume the xmax probably isnt large enough to justify a 6" diameter, but at least do a few 2" ports or a 4" port. But lets just say that 1 10" RF HE sub had port noise with a 3" port (tuned to 35hz) and slightly flaired at the end. Not enough to hear it in the car I would think, but still, that was just a 10" sub, with a bigger port than yours, and it made noticeable noise when you are in the same room. But that box was from their manual, so like I said, I think the vent mach was too low to hear if it was in your trunk.
    Matt
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by fantomas
    Yeah, I have a 1000Watt 4 channel Boss amp. The first 3 Subs that I had, it blew them out. Only later did I realize, it wasn't the amp blowing the subs, it was the box. once I threw the box in the garbage, I made my own box and bought myself 2 10" Lightning Audio Subs, and I have my front speakers amped up with the same amp. Have had this setup for about 2.5 years, not 1 hickup.
    But, I had a 600Watt Boss AMP, that I paid $50 for, it was a complete POS. So basically, it all depends on which Boss amp you get. If you want to see the one that I got, it's on the 4th page of my Cardomain page in my sig.
    Peace,
    Rafster
    Constant Bitrate CHUPACABRA's Avatar
    Mar 2004
    G'ville S.C.
    Quote Originally Posted by beezm
    Id scrap that whole design.if u want to go ported do a 10"X3" side port that runs a 3/4" mds baffle board down the back of the inside of the box.Find out what is the port size u need for the subs u have and just tune the length to that.If u need help IM or PM me.
    As far as your speaker choice goed stay away from that sub,Blau is a good brand for HEAD UNITS AND COAXILS but subs.....thay suck.this is where u want to spend the most money,if I were u Id get some alpine typeS subs I have some in my wife's car and let me tell you thay sound better than some of the "so called HIGH END" stuff that I install for most ppl. Or if u want to go original get some PLANET AUDIO or FUSION subs.
    2-15" ILO lcd w/DVI
    6800 gt Duel DVI out
    p4 1.6ghz flex atx board
    1gb 400 ram
    120gb(2-60gb raid) sata hd
    2-60gb hotswap
    WIN2K Pro SP2
    M.A.M.E. w/2,300 games
    CARPuter info
    Apr 2005
    Thank you so much guys =D
    As far as the speakers, yea I'm not looking to spend much on this system. Only reason I'm doing it is if I can do it relatively low cost. The Blaupunkt's are normally around $70 /each, I am able to get em for $70 for two of em brand new. That's primarily why I am going to go with them. I have read a few things about them, most say as long as the box is built correctly they will sound just fine. I figured this too, with 212W RMS going to each one, they should pound pretty good.
    With the box design, I am going for a goal of around ~2.0 Cubic Feet per speaker. With the ports, I read that for these speakers 1 port 2" in diameter and 3" long is what I should use. Apparently this isn't going to perform very well ?
    Should I go with a bandpass box ? Or what ?
    Chupacabra, I'll be IM'ing you on MSN soon probably ;D, lol.
    Thanks again, anymore recommendations are very welcome =)
    ------- EDIT
    Hey, I used some calculators on carstereo.com to figure out some measurements for my ports. mbuchman pretty much had these numbers up above too.
    I entered the following info:
    # of Drivers : 1
    Xmax : 5.6mm
    Tuning Frequency: 35 Hz [Not sure what this is, got the number from mbuchman, someone explain further plz?]
    It spit out these results:
    Minimum Diameter : 3.7 In
    Minimum Area : 10.74 In [Guessing this is the length]
    Then I skipped down and did the next one, to calculate vent length.
    # of Ports : 1
    Enclosure Volume : 2.0 Cubic Feet
    Tuning Freq. : 35 Hz
    Diameter : 4 in
    Says it needs to be 10.9" long, I should be able to easily fit this into the plans for my box, I plan on modifying it quite a bit, I'll be posting it back up soon to get more suggestions on it.
    Where can I find ports this size ? I can't find em anywhere on the internet, any ideas ?
    - BeeZm
  1. VW Jetta 2003 Sound Question
    By aegray in forum Newbie
    Last Post: 01-12-2005, 07:06 PM
  2. Line converter with a Delco Bose system?
    By JGeek in forum Newbie
    Last Post: 03-27-2004, 02:46 AM
  3. MPX play and sound not working
    By dudah85 in forum Software & Software Development
    Last Post: 11-05-2001, 02:52 AM
  4. Mpxplay doesnt work with Sis530 sound system onboard
    By zamboni in forum Software & Software Development
    Last Post: 06-23-2000, 01:11 AM
  5. How do you get sound in to your system???
    By DaPyro in forum General Hardware Discussion
    Last Post: 02-28-2000, 01:10 AM
