Results 1 to 10 of 11
Thread: Replacing Headunit with PC
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Well I just got Sirius Starmate receiver and I'm putting the PC in really soon (next week) and it dawns on me, what do I even have a radio?
    I'm thinking of getting a USB FM receiver and just plugging the carpc's lineout (or a better card in the laptop dock) and connecting it to the amp. That would open up the whole center console for me to put some other gizmos.
    Any reason why this wouldn't work? Any ideas on how to do it? I've searched quite a bit here and it looks like many are doing it, I just couldn't find much on how.
    Any comment on how to progress would be appreciated.
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    no reason why it wouldnt work. many people (including myself) go this route. not only does this leave space open to put stuff, but it also opens up room to put your screen (if your HU is double-DIN)
    Your everyday carpc geek and tech guru at your service. *bow*
    Apr 2005
    Boston, MA
    Quote Originally Posted by Vchat20
    May I ask how? I'm a dumbie when it comes to car audio. Are they just line level inputs into most amps? What about front and rear?
    Spring Hill, Florida
    Read this sticky at the top of the Newbie forum:
    HOW TO: Get sound from PC to Car Stereo / Amp
    2005 Black Chevy Impala
    May 2005
    I think it should be no trouble. I was thinking of doing the same thing. Except my car has 6-speakers stock. I figured if i get a 4-channel amp / or switch to component speakers with an amp. And use another 2-channel amp for the rear deck. With most motherboards today, they come with optional 6.1 surround sound. You could with 6 channels between the amps, take each line-out and split them into left and rights going into the amp. Now you have yourself 6-channel surround and i assume optional sub. It may get tricky with all the amps and running power but I think it may result in some nice sound.
    Apr 2005
    Boston, MA
    Quote Originally Posted by Shelbrain
    Don't see how I missed that
    Anyway, read all nine pages, so it looks like it should be possible. Still not much detail on the people running this particular setup.
    I guess I'll have to pull out my seat and look at the amp to see what type of connections are on the amp. There definitely no aux-input or anything.
    Jan 2005
    Warren, Ohio, USA
    if you have a factory amp in your vehicle, it should still be doable with a bit of work. more or less, you are going to have to go to a place such as installer.com and see if you can find an integration harness for your specific model.
    Apr 2005
    Boston, MA
    My chrysler's shares almost everything with the mitsu eclipse. I've got to verify that the amp is the same, but I think this thread from last week has the adapter I'm looking for.
    Constant Bitrate Malenko's Avatar
    Jul 2004
    Newark,De
    I have the MITAH adapter, round end on one side, 4 RCA wires and a power wire.
    Want it? PM me
    [IIIIIIIIII]95%
    Dynamix 7" LCD Touchscreen Monitor
    VIA Epia M10000 Motherboard
    Samsung 40 gig 2.5" Hard drive
    Slimtype LSC-24082K DVD/CDRW
    1024MB DDR RAM
    Morex 3688 case w/ psu
    Apr 2005
    Boston, MA
    Well I gave metra a call. They told me I need a Metra Turbowire #70-1818 (CHRYSLER LOW-LEVEL AMP INTERGRATION HARNESS).
    It's under $20 bucks. Hopefully it works out.
  1. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 03:10 AM
  2. External PC Card adapter for Verizon BroadbandAccess
    By Bluebisz in forum Wireless Communications
    Last Post: 02-24-2005, 10:11 AM
  3. In progress car PC install.
    By Arathranar in forum Fabrication
    Last Post: 10-20-2004, 01:49 AM
  4. home pc problem
    By Mitokondria in forum Off Topic
    Last Post: 08-05-2003, 12:36 PM
  5. remote turn on lead from headunit to power up PC
    By BluCivic93 in forum General Hardware Discussion
    Last Post: 07-27-2000, 03:13 PM
