Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Amp remote on without HU
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    Did a tiny bit of ing and couldnt find what I needed to know...
    How would I get my amp to turn on and off as the HU used to when I turn the car on/off...
    Where would I now connect my remote on wire?
    (All done)
    iPad Mini 128GB, RF 600.5 amp, JL12W0V2, 8 Infinity Components
    Maximum Bitrate MaleBuffy's Avatar
    Aug 2003
    Greece
    With the 12V+ of your ignition...I think the blue wire....Just check it with a multimeter....turn your key on and off, and if its 12V+ and 0V then its the correct wire!
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    tap into a fuse in the fuse box. look for the one labeled radio acc...thats what i used and its fine. as long as it turns on and off with the ignition of the car you should be fine.
    Variable Bitrate mp3hombre's Avatar
    Aug 2002
    Montreal / Los Angeles
    For convenience, use a switch between the wire where the radio B+ was connected to and the remote of your amp.
    Aug 2004
    Floreeda
    Kool, ill just tap the ACC wire that my HU used to use....
    (All done)
    Variable Bitrate Osiris's Avatar
    Atlanta (kennesaw) GA
    Quote Originally Posted by mp3hombre
    I second this advice. I use a switch and it has been priceless.
    Osiris Networx
    --Tuning is all about price vs performance. You've got to find your own medium.--
    Aug 2004
    Floreeda
    I dont want to hit a switch to turn my amp on and off.
    I got a switch already, its called my key in the ignition.
    (All done)
    Apr 2005
    Some head units have a remote wire out, so check if your does. It it doesn't I'm pretty sure you can plug it up to the electric aerial 12v output. The advantage to this is if you turn the head unit off the amp will tirn off aswell and you won't get a hum.
    Constant Bitrate Malenko's Avatar
    Jul 2004
    Newark,De
    Quote Originally Posted by Aus_Ben
    what he said, or tap the radio power wire.
    [IIIIIIIIII]95%
    Dynamix 7" LCD Touchscreen Monitor
    VIA Epia M10000 Motherboard
    Samsung 40 gig 2.5" Hard drive
    Slimtype LSC-24082K DVD/CDRW
    1024MB DDR RAM
    Morex 3688 case w/ psu
    Mar 2001
    If the timing of your amplifier turn on is important, you might look at getting a dssc. It ties into your ignition and can turn on your amps, your carputer, your usb hubs or whatever else.
    It's $49 bucks though, but it comes with an automotive relay and all the wires, connectors, etc.
    Hell, you could spend more than $49 bucks on wires, relays and solder/soldering iron from Radio Shack trying to build your own circuit.
    Check out my carputers:
    DVD, GPS, MP3, 6.4" LCD Touchscreen, 5" Headrest LCDs, PSone, DSSC, etc.
  1. CarPC Remote control of FM Radio / Amplifier within Blaupunkt HU
    By ProCos in forum General Hardware Discussion
    Last Post: 05-28-2011, 09:56 AM
  2. Amp or HU dilemma
    By paul167 in forum Car Audio
    Last Post: 11-03-2004, 05:45 AM
  3. Replies: 1
    Last Post: 09-06-2004, 12:52 AM
  4. Amp Remote Turn-on via PSU?
    By bulgogi777 in forum Car Audio
    Last Post: 08-24-2004, 10:58 PM
  5. PC -> Amp and HU - Amp question
    By Nokia6600 in forum Newbie
    Last Post: 03-24-2004, 04:42 AM
