Results 1 to 7 of 7
Thread: using the aux input on a Sony xplode head unit
    May 2005
    I own a Sony CDX-MP40 and want to use the aux inputs with something else besides a sony cd changer or mini disc player (ie using an ipod without the stupid transmitter). But you cant since sony has that bus thing that needs to be told something is there so it will unmute the aux input. I have heard of boxes that will do this for you, but have had no luck finding them. Have any of you heard of such a thing or know of any mod I can do to use the aux inputs? Thanks
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    This is what you need: http://www.discountcarstereo.com/detail.aspx?ID=361 unless you'd like to add a cd changer then this is your other option: http://www.logjamelectronics.com/piesonaux.html. The second one requires the cd changer to be present. The first does not.
    ATVMS.com
    Nov 2004
    NYC
    I have a Sony CDX-CA900X
    From the manual:
    The unit's AUX IN (external audio input) terminal on this unit is also used as the BUS AUDIO IN (audio input) terminal. You can listen to the sound from your car speakers by connecting optional *Sony* portable devices.
    Note
    If you connect an optional CD/MD unit, you cannot connect any portable devices and cannot select "AUX".
    To activate auxiliary equipment in the music source display:
    1. Press OFF
    2. Press MENU
    3. Press the UP or DOWN arrow until "AUX-A...off" appears.
    4. Press the RIGHT arrow to select "AUX-A...on" appears.
    5. Press MENU
    Now, I haven't had to go through all of that because as soon as I disconnect my CD changer, I can select AUX as one of my sources.
    *- I have played music on my iPaq and Ipod using this connection, so the "Sony portable devices" statement is just legalese.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I have a Sony Xplode CDX-F5700 and don't have any issue with the bus line. I use the aux in for the carputer and switch between sources like DRweside describes.
    The AUX in also doubles as the bus in unit and says that if you have the CD/MD unit connected, you can't connect any portable devices and AUX won't appear in the display as a source.
    To select the aux in, press "source" repeatedly to select "AUX".
    Want to:
    Nov 2004
    NYC
    Crap. Maybe I shouldn't have edited my whole post. Anyway, AUX In is one of the reasons why I stick with Sony HU's.
    May 2005
    But there is a problem, my sony hu doesn't have a menu button! Is there a hidden menu or something i can get to to turn on the aux input? I would like to do that instead of buying something.
    May 2005
    Perth, WA, Australia
    Quote Originally Posted by [jarod]is[root]
    My menu button is on the remote for my Sony, otherwise try reading the manual to see if it mentions another way
  1. Can a car-computer replace a stereo head unit?
    By CA 3000GT in forum General Hardware Discussion
    Last Post: 11-13-2006, 10:24 PM
  2. FS: Pioneer Head Unit (DEH-P3500) w/ RCA input cable
    By Eclipse-GST in forum Classified Archive
    Last Post: 02-19-2005, 12:33 AM
  3. Aux input for Sony head unit?
    By joer4 in forum Car Audio
    Last Post: 02-11-2005, 03:09 PM
  4. FS: Kenwood Aux In Stereo Head Unit adapter. $12.50 shipped to US.
    By LESLIEx317537 in forum Classified Archive
    Last Post: 04-27-2004, 09:14 AM
  5. Sony head unit aux in?!?!?!?
    By Roadrunner in forum General Hardware Discussion
    Last Post: 12-05-1999, 03:12 AM
