Results 1 to 5 of 5
Thread: Problem Connecting both CarPC & H/U Audio in Amp!!!
    Jan 2005
    I don't have an aux in option on my H/U.
    Using 2 into 1 RCA "y adaptors" to connect both carpc (MII12000) & Alpine H/U (line level output) into my amp (4 channel) is causing problems. With just the carPC connected to the amp audio is great, until you connect H/U input (also line level) into y adaptor simultaneously, in which case volume drops dramatically and interference is audible (even where the h/u is switched off). Vice versa is also true.
    I've searched the forum and have found this should not be a problem (eg. Looking for a 2-way audio switch.
    Only option I can think of is to connect the H/U into the CarPC line input and only run one source into the amp however this may have its own issues???
    Oct 2003
    Netherlands
    Depends on the type of radio you have, if you have the possibility of an
    AI-net cd changer you have an audio in on your radio.
    There is a converter cable from RCA to AI-net.
    Low Bitrate ALonDonThinG's Avatar
    Aug 2004
    London
    I have the same problem. ive found this info http://www.tkk.fi/Misc/Electronics/c...s/linesum.html i have ordered the bits to make the circut, i let you know if it works.
    The other way is to use an audio control unit with aux in, @£300 , or an rca switch box, but if like me , you will want them on at the same times so you can hear your gps talking.
    Epia SP1300\512 ddr\40g 3.5" hd\cartft-touchscreen\GPS-destinator \M1-ATX\Audigy1\Linksys-wirelessB\anafekkingbigamptojblspkrs.
    Jan 2005
    Quote Originally Posted by ALonDonThinG
    Yeah, that's exactly what I'm wanting to do! Interested to see how you go.
    How exactly does one go about applying the resistor to the cabling? Does it go on the centre conductor (audio line) or shielding?
    Also, I take it where I split 2 RCA outputs from carPC into 4 (for conecting into 4 channel amp), I only need to apply two resistors before splitting?
    Aug 2004
    London
    Hi togaf
    Ive solved my problem, but in a different way, when i ordered the resistors i also got a ground loop isolator, ive installed this between the radio and my line in on carpc and
    BINGO! all clear now. This is the best solution for me, i also used an rca switch box
    so it is possible to use the radio with carpc shutdown. If you try to make the mixer, apply the resistors to the center signal wire.
    Good luck , pm me if you get stuck.
  1. Insight P4 Itx Audio out problem
    By OoNikFraleyoO in forum General Hardware Discussion
    Last Post: 01-05-2006, 02:24 PM
  2. Loud and distorted audio problem (EPIA / M-Audio)
    By -al- in forum General Hardware Discussion
    Last Post: 10-10-2003, 08:29 AM
  3. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 02:21 PM
  4. Having problems running audio from my Shuttle to my amp
    By 0din in forum General Hardware Discussion
    Last Post: 06-19-2003, 02:41 AM
  5. Hooking audio out to Amp?
    By Alphared in forum General Hardware Discussion
    Last Post: 04-30-2003, 10:43 AM
