Results 1 to 4 of 4
Thread: Carputer audio Noise
    Constant Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    Hi,
    I am using a inverter what is the best way to eliminate audio noise.
    Just was wondering what the most of you do to eliminate noise in the Carputer assuming it is because of using a inverter.
    Seems like what I have to do is have 5 seperate grounds attached to the case and the computer power supply. That eliminates about 98-99% of the noise but was wondering if there is a better way of doing this insted of having all the extra wires attached to the Carputer. 1 or 2 larger gauge wires does not help either. seems like it wants the 5 seperate wires. (4 14ga and 1 4ga wire).
    any suggestions to use less wires?
    Michael
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Isolator
    Feb 2005
    Huntsville, AL
    Quote Originally Posted by thanatos106
    Isolator
    Thanks for your reply
    The ground loop Isolator does not take all of it away and ground loop isolator seems like it changes the quality of the sound (gives it more like a "fm" radio sound.
    Any other ideas out there?
    Variable Bitrate Osiris's Avatar
    Atlanta (kennesaw) GA
    Not sure if it works but depending on the size of the ground wires you may want to get some bigger ones. Also people have suggested grounding them all to the same point and grounding the actual inverter case.
    Osiris Networx
    --Tuning is all about price vs performance. You've got to find your own medium.--
  1. Replies: 7
    Last Post: 02-07-2005, 07:35 PM
  2. Movie Audio Quality through carputer
    By Ne0 in forum General Hardware Discussion
    Last Post: 02-06-2005, 09:17 AM
  3. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  4. Need help with audio install
    By Zebelkhan in forum Car Audio
    Last Post: 01-24-2005, 05:15 PM
  5. Audio noise, only with Lilli LCD on.
    By muldrick in forum LCD/Display
    Last Post: 08-11-2004, 07:45 AM
