Results 1 to 6 of 6
Thread: how much noise does a computer make?
    Low Bitrate ketchup318's Avatar
    Jan 2005
    Monterey Park, CA
    i currently have my carputer right next to my amp. All the connections are facing my amp, i.e. VGA out, USB, opus power lines... etc, and i also am not using the I/O shield.
    I was wondering since this is all facing my amp (speaker-wire side), will this make any noise? it does look cleaner cause all the wires run down the middle between the two components (power, ground, usb lines, speaker lines, vga cable... etc) thanks
    AMD 1700 & Abit VA-10 w/ 512Mb PC3200 Corsair Ram
    60GB 7200rpm HD - Opus 150W PS - Lilliput 7" TS
    Panasonic Slot DVD - SD Audigy NX 2
    Phoenix Gold 5.1 MT Amp - 2 USB Hubs
    Hauppauge WinTv USB2 - Holux GPS - Belkin Bluetooth
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    It sounds like you already have your computer installed. Can't you just turn it on and see if it causes noise?
    Want to:
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    after the cars off and the stand-by is starting...you can slightly hear the processor fan...thats about it, depending on what car you have. You DEFENTLY cant hear it while your driving.
    Jan 2005
    Monterey Park, CA
    i was refering to interference, not fan noise. does it generate any interference cause amp and the computer w/ psu are so close to each other?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Bugbyte
    I am with you one this.
    If you didn't have it yet, it is obvious to ask.
    But sound like you already did, flip the switch on to see if there is any.
    BTW, if you keep power wire a way from audio wires, there will be less (or no) noise. Other interference, maybe not cuz my PC is on top of the amp separate by particle board and has no problem.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Variable Bitrate proTONEd's Avatar
    Jun 2004
    Belgium
    In most cases noise is being produced by bad grounding.
    And like MatrixPC said: be sure to keep power wires and speaker wires apart.
    You can bring it down to the following: how bigger the current that flows through the wire the more interference it can produce to other equipment.
    Best thing is probably just to try and see.
    Why is it drug addicts and computer afficionados are both called users?
    Currently : Audi A6 - no install
    Second install : VW Passat '97 CarPC
    First install : '87 Audi 80 CarPC
  1. Cutting power to USB after computer has shutdown
    By lookinco in forum Power Supplies
    Last Post: 05-17-2006, 01:05 PM
  2. Noise (from engine and other sources) HELP!!!
    By sstylos in forum Car Audio
    Last Post: 09-20-2005, 12:41 PM
  3. Replies: 86
    Last Post: 04-04-2005, 03:57 PM
  4. Noise problem -- finally found the source!
    By sq_geek in forum General Hardware Discussion
    Last Post: 11-14-2004, 11:49 PM
  5. Noise!! AARGH!
    Last Post: 09-21-2004, 01:33 PM
