Results 1 to 10 of 10
Thread: BMW fuse Info
    Constant Bitrate ltrain1007's Avatar
    Jan 2005
    NJ
    BMW fuse Info
    Anybody got any? Ive been searching, and i cant find out what fuse to check for my radio. My 12v switched wire has stop responding, i need to see if the fuse is blown. is there a mapping or anyone have experience?
    Go on and do it, do it, Do it 'til you're satisfied,
    Whatever it is, do it, Do it 'til you're satisfied.
    CarPc progress |OOOOXCOOOO| 57%
    Jan 2005
    NJ
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    owners manual? normally has what fuse is for what / where they are.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Jan 2005
    NJ
    i didnt think to check that, was only checking online sources, ill look at that when i get home from work, thanks.
    Jan 2005
    NJ
    its not in the manual, i guess no one knows ?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Oct 2003
    Or just try looking on the bottom of the fuse panel cover...
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Or under the hood!!
    My truck has the AMP and audio fuses next to the battery.
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by thanatos106
    Or under the hood!!
    Yeh. I somehow blew a fuse and looked in the manual and couldn't find it there. Turned out that it was one of those fuses in the engine compartment. I didn't even get to read about those, even though they were in my manual
    Jan 2005
    NJ
    in the e46 the fuse is under the hood, i was looking at the many plugs but i dont know which is the one im looking for, and there is no writing anywhere ,not even in my manual!! someoen on the other forum posted the same problem tonite so we will see what happens . . .
    edit: found fuse box in glove compartment and fixed it !
  1. Fuse popping, wire heating up!
    By gumbi4u in forum Power Supplies
    Last Post: 06-29-2006, 10:01 AM
  2. Lilliput Lcd fuse blown help!!!!
    By fernando11554 in forum LCD/Display
    Last Post: 05-16-2005, 11:54 AM
  3. Xenarc fuse and power help required
    By Scouse Monkey in forum LCD/Display
    Last Post: 02-18-2005, 02:45 PM
  4. File Info / Movie Info
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 04:42 PM
  5. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 04:59 PM
