Results 1 to 3 of 3
Thread: sub positioning
    Jun 2004
    Graham, WA
    sub positioning
    Hey guys im working on a sub box in the fender wells I got the base down but I gotta position where the subs gonna sit now so I need some input on whats gonna sound the best. heres the pics
    what the base looks like right now
    aimed forward
    aimed straight across
    also any ideas on how I could inset the sub a lil so I could put a plexi front on it for protection woudl be great
    Low Bitrate Stonewall78's Avatar
    Dec 2003
    Calgary, AB
    It is best to angle it a little if you plan to put a second one on the other side. You can make the sub recessed a bit by building a bigger ring around the one you already have and stretching the fleece around it. Make sure to make the diameter a little bigger then your sub size for when you stretch the fleece around your frame and for fiberglass reenforcement.
    Jun 2004
    Graham, WA
    I seen after I posted on a site where it said to do the ring thing but would that be enough room for a plexiglass cover? And will it be ok to put a plexiglass cover over the sub on a sealed box?
  1. Alter the D3 positioning icon
    By Matthew230 in forum Map Monkey
    Last Post: 10-21-2005, 07:10 AM
  2. Hard drive orientation / positioning
    By Pabs in forum General Hardware Discussion
    Last Post: 09-03-2004, 12:35 PM
  3. Sub positioning
    By cheerio in forum Fabrication
    Last Post: 08-20-2004, 05:59 PM
  4. ME window positioning problem
    By siueclipse in forum ME Archive
    Last Post: 12-22-2003, 01:54 PM
  5. GPS Positioning
    By cyborg5000 in forum GPS
    Last Post: 10-27-2003, 11:32 AM
