Results 1 to 8 of 8
Thread: AUX amplified help
    May 2005
    AUX amplified help
    i have a kenwood headunit, psw 9527
    with aux in, from my laptops standard audio output
    the volume from tuner and cd is far louder then the audio on aux (from the px)
    i have tried turning everything up on the pc, and even cut the aux phono leads to a minimum, but its still quiet
    is there any mini (small) sized IN LINE style adapter, that goes between the laptop 3.5 out to the kenwood AUX PHONO RCA In??
    to boost the volume a bit, thanks
    Low Bitrate ALonDonThinG's Avatar
    Aug 2004
    London
    No magic adapter is gonna boost ur lineout level from the laptop, you need to use a linedriver, this will boost your signal. Maybe using an external soundcard will help, but it will still sound quieter than the HU itself. If your system runs via an amp you may get a better result than just using your HU.
    Epia SP1300\512 ddr\40g 3.5" hd\cartft-touchscreen\GPS-destinator \M1-ATX\Audigy1\Linksys-wirelessB\anafekkingbigamptojblspkrs.
    May 2005
    my old sony head unit had a aux boost level on it.
    made it better, so surely there is electronics out there to do the job
    Apr 2005
    I use a couple of these LD-1 amps, one for my DVD input and one for the AUX input on my HU
    May 2005
    do u have a photo,
    how big is it, and whats it powered by, she site has no pics
    May 2005
    also does it have an adjustable volume boost of somesort?
    May 2005
    your on clubarmarda aint you mate
    Apr 2005
    This site has a photo of the amp. http://www.discountcarstereo.com/detail.aspx?ID=317, It's just a little bigger than a pack of cigs. There is a volume control as well.
    Yea thats me over there, you have a boat too?
  1. Replies: 6
    Last Post: 05-19-2005, 09:59 AM
  2. using the aux input on a Sony xplode head unit
    By [jarod]is[root] in forum Car Audio
    Last Post: 05-15-2005, 08:17 PM
  3. No aux on pioneer?
    By dyeinbreed in forum Car Audio
    Last Post: 03-11-2005, 02:51 PM
  4. Head Decks that DEFINITELY have AUX in?
    By inmytree in forum General Hardware Discussion
    Last Post: 11-02-2003, 01:56 AM
  5. Panasonic Headunit - MAKING an AUX in..
    By captain_jim1 in forum General Hardware Discussion
    Last Post: 08-07-2003, 04:36 AM
