Results 1 to 9 of 9
Thread: Jetta 2004... Wire code... Need help.
    May 2005
    I got a Jetta 2004 with the double radio (cassette and cd), i manage to pass a power wire from the battery to the trunk.
    But cannot find a way to "power up" my amp. Is there a wire that could turn on my amp and my capacitor?
    Here what i got : Sony Xplod 1000W, Box with 2 12" Infinity spk, 1 farad Stingpro capacitor. Ans since there is no rca output on my Jetta radio, i also got a small box that convert spk signal to rca connector.
    Thank you for helping...
    REXTHEGREAT
    Low Bitrate Stonewall78's Avatar
    Dec 2003
    Calgary, AB
    Since it seems you can't use the or I thought I would be nice today
    Aug 1999
    Washington D.C.
    That diagram is dated in 1997. It does not apply to 2004 Jetta. I have the same car and the connector looks and works differently. You aren't going to find that "turn on" wire car because it's controlled over CAN-BUS. CAN-Bus also controls the dimmer/illumination wire. Search on vwvotex.com to see where you can tap an accessory wire. You'll find a good point under the steering wheel in a power distribution block.
    Feb 2005
    DC
    Quote Originally Posted by Zip-Lock
    You might wish to try vwvortex.com
    Dec 2003
    Calgary, AB
    So the mk3 and 4 wirring is the same, if your deck is can there is a switched wire above where your deadpedal is right below the relay panel.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Hope this helps
    2004 Jetta
    Security
    Battery RED + (+) IGNITION SWITCH HARNESS
    Ignition GRN (+) IGNITION SWITCH HARNESS
    Starter01 BLK/YEL + (+) IGNITION SWITCH HARNESS
    AllDoorTrigger BRN/VIO (-) (-) DRIVER'S KICK PANEL AT DOME DELAY RELAY
    TrunkTrigger BRN/BLK (-) (-) AT TRUNK LIGHT
    HoodTrigger N/A
    FactoryAlarmDisarm N/A
    ParkingLights GRY/YEL L (+) GRY/WHT R AT LIGHT SWITCH
    Security
    Parking Lights
    ALSO (+) GRAY/WHITE-DIODE ISOLATE
    Remote Start
    Ignition02 + IGNITION SWITCH HARNESS
    Ignition03 +
    Accessory01 VIO + (+) IGNITION SWITCH HARNESS
    Accessory02 +
    AntiTheftSystemNONE
    Tach BLK (-) (-) AT DIAGNOSTIC CONNECTOR
    SpeedSense BRN/RED (AC) REAR AXLE
    BrakeLights GRN/RED (+) AT BRAKE SWITCH
    ReverseLights BLU/WHT (+) AT REVERSE LIGHT SWITCH
    Horn BRN/YEL (-) AT STEERING COLUMN
    Doorlocks / Window
    PowerUnLock GRN/BLU (-) (-) NEGATIVE TRIGGER
    PowerLock YEL/BLU (-) (-) DRIVER'S KICK SPK "KEEP RELAYS UPRIGHT"
    Convenience
    HeadLights YEL/GRN (-) AT LIGHT SWITCH
    LowSpeedWipers BLK/RED (-) (-) AT WIPER SWITCH
    Mobile Audio / Video
    Ground BRN - (-) RADIO HARNESS
    PowerAntenna WHT (+) RADIO HARNESS
    FrontLeftSpeakerPos WHT
    FrontLeftSpeakerNeg BLK
    FrontRightSpeakerPos WHT
    FrontRightSpeakerNeg BLACK
    RearLeftSpeakerPos WHT
    RearLeftSpeakerNeg BLK
    RearRightSpeakerPos WHT
    RearRightSpeakerNeg BLK
    Amp BEHIND REAR SEAT
    Control Modules
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    Quote Originally Posted by Stonewall78
    that would be a negative...
    Dec 2003
    Calgary, AB
    Quote Originally Posted by strohj
    a negative to what?
    Apr 2005
    hey, fyi theres no switched power behind your head unit, get a voltmeter and test the fuses on the side of your car, between the door and the dash (drivers side) for a switched power, thats how i wired mine
  1. 2004 Jetta Factory steering wheel controls
    By Zip-Lock in forum Input Devices
    Last Post: 06-28-2006, 02:10 AM
  2. Morex 60W car kit - 4 or 6 wire?
    By MVShibui in forum Power Supplies
    Last Post: 05-09-2005, 01:28 PM
  3. Where is 2003 Jetta Ignition Wire?
    By weazelb0y in forum Power Supplies
    Last Post: 03-27-2004, 07:28 PM
  4. ignition wire for opus psu
    By liquid_smoke in forum Power Supplies
    Last Post: 09-09-2003, 10:58 PM
  5. Power Supply wire color code?
    By JustAGuy in forum Power Supplies
    Last Post: 06-17-2002, 01:53 PM
