Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Buzzing noise help
  1. #11
    Apr 2005
    Birmingham UK
    I will check that mate. I have bought a audio surpressor which what DJ's use appently which is supposed to filter out every noise apart from that of music which I should recive by today so Im gunna give that a try also. I was doin so well till this problem! All I need to do is get rid of this noise properly mount the Graphic and the install is complete!
  2. #12
    Constant Bitrate emdzey01's Avatar
    Jan 2005
    san fernando valley
    try changing your power supply. maybe even switch to opus dc-dc so you can throw away your inverter too. if the buzzing stops when you plug it in your house that most likely is an electrical/grounding issue, not the sound card.
    Brushed Metal for Centrafuse 1.4
    Brushed Aluminum for Centrafuse 1.4
    xenarc 700ts | via epia-m10k | audigy2 nx | holux gm-210 | usb wifi | 40gb 2.5" | slot-load dvd-cdrw | morex 3688 | opus 150w | centrafuse, iguidance
  3. #13
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by fletcher5555
    Try a ground loop isolator. The suppressors commonly go on the power connections, and most will not support a big load.
    As some of the others say, have you looked at a DC-DC PSU that's actually built for in car use? It's a lot more efficient than using an invertor and if your hardware is suitable for it will make your life a lot easier. I remember when I used an invertor a few years ago and it was a PITA (this was before you could buy shutdown control for them) and I would NEVER go back to using an invertor even if you paid me.
    Edit: this is probably my last post in this thread, as we seems to be all telling you the same answer to your SIMPLE problem again and again.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  4. #14
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    yes I second the motion, once you go DC you'll never go back.. biult in startup shutdown controller, small foot print, etc..
    I still have an inverter for other things I use fromt iem to time.. but there is no reason to purposly introduce a 60hz buzz on the system.. I also use mutiple grounds, keep grounding till it stops..
    I made my own ground loop isolater for about $10 from radio shack parts.. they have mono channel isolators.. just buy 2 and there ya go.. since going to cd I have not needed it though.. dumping my head unit helped too..
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
  5. #15
    Nov 2004
    NYC
    Make sure your power supply is grounded. I had the same problem and the fix was running a short lead from my ground distribution block to the neutral(?) prong on the PS's power cable. I never tried running the lead directly to the PS's case, but I guess it should work. The problem is that the inverter doesn't provide adequate neutral and ground circuitry.
  6. #16
    Apr 2005
    Birmingham UK
    OkI see guys above like Stevie G gettin a bit short with me but if you read the 1st post youd see that I tried a Dc power using the carnetix P1900 which blew up to the extent it nearly burnt all my dash and me in the process! Now call me abit dubious but I really dont wanna risk that again to be honest and their isn't anything else on the market that can power my Iwill Mini. Thanks everyone for your advice though I really do appreiciate it.
  7. #17
    Nov 2003
    Marietta, GA
    fletcher5555,
    My apologies for your problems with the P1900. I think you may have pointed out an inconsistency in the wiring information on your IWill power connector. Please do me a favor and take a look at your AC adapter.
    1) is it's part number FSP120-AAB?
    2) does it have a pin-out label on it?
    3) are pins 1 & 3 labeled GND (earth) and pins 2 & 4 labeled +V?
    or
    4) are pins 1 & 2 labeled +V and pins 3 & 4 labeled GND?
    Please let me know what you find. I would be happy to send you a new unit to try.
    MikeH
  8. #18
    Aug 2003
    Warwickshire, UK
    The point was not about the DC-DC PSU, it's mainly about the ground-related buzzing noises and people's similar solutions, which you didn't state whether you've tried or not. Feed back is important if you want people to help you. I'm not getting short with you whatsoever, sorry if you got that impression I'm simply being honest.
    Also, you don't state anything about the carnetix in the first post in this thread.
  9. #19
    Apr 2005
    Birmingham UK
    Cheers every1 Problem sorted
    Sorry Stevie G I think its called avin a bad day at the office and this buzzin was really starting to get to me. I did try everyones suggestions and I think in using every1s suggestions the buzzing has gone and im so happy with the install now its untrue. Ill see If i can post some pics very soon. My appologies again for flying off te handle and my thanks to everyone who offerd their helpo. Cheers guys!
  10. #20
    Aug 2003
    Warwickshire, UK
    Glad it's and working well!
    Don't worry I know the feeling mate! I'm a lot more relaxed now it's the bank holiday Weather's looking good around here (Nuneaton) so probably have a BBQ on later and once the beer's flowing things will get even better
  1. power supply buzzing help thing i found... read if u have noise
    By TimW in forum General Hardware Discussion
    Last Post: 02-25-2012, 12:48 PM
  2. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 11:31 AM
  3. Buzzing noise when shuttle is plugged in
    By mazda3uzr in forum Car Audio
    Last Post: 12-22-2004, 09:59 PM
  4. More details on my buzzing noise....
    By sq_geek in forum General Hardware Discussion
    Last Post: 11-02-2004, 01:46 PM
  5. noise investigation
    By lookinco in forum Power Supplies
    Last Post: 09-23-2004, 03:41 AM
